jalba Posted June 10, 2013 Share Posted June 10, 2013 Hi, Now practicing with geometric constraints, so sorry for sounding amateurish. Now I got a hand on applying geometric constraints to my lil sketch (see attached). However, I would also like to have my dimensions work in accordance with the design i.e. when my width increases, the dimension (in red) should also increase with it. I know that I can switch the dimension constraint from "dynamic" to "annotative", but that does not give me the view that I desire. Thanks for any ideas. Practice with Constraints.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 10, 2013 Share Posted June 10, 2013 I don't remember how to do it - but you are not supposed to have to redimension the model. (extra - duplicated work) There is a way to use your parametric dimension as an annotation when you go to paperspace Layout that looks no different than standard way of placing dimensions (exept that they are associative and driving rather than driven dimensions). Become very familiar with Nearest osnap (automatically adds coincident constraints that are otherwise not possible or must be done manually). I recommend you Lock a datum. Quote Link to comment Share on other sites More sharing options...
jalba Posted June 10, 2013 Author Share Posted June 10, 2013 OK, I know how to change the constraint dimension from dynamic to annotative, but how can i not have it display as "d1=*****" or "fx:*****"? Not entirely following the neareast osnap option also. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 10, 2013 Share Posted June 10, 2013 ...., but how can i not have it display as "d1=*****" or "fx:*****"? I am pretty sure there is a way (if I remember correctly from training session), but my memory is not good enough to recall exactly how (I seldom use AutoCAD anymore). It might be only when you go to Layout that the parametric function symbol disappears. Quote Link to comment Share on other sites More sharing options...
jalba Posted June 10, 2013 Author Share Posted June 10, 2013 Got it. Thanks for the home lesson Quote Link to comment Share on other sites More sharing options...
jalba Posted June 10, 2013 Author Share Posted June 10, 2013 Just a question though..... Can dimension constraints be connected to tables i.e. when u enter a figure on the table, the dimension constraint adjusts automatically to that figure. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 10, 2013 Share Posted June 10, 2013 When you click on the Parameters Manager there is a table of your dimensions and you can edit these and our dimension constraints automatically update the figure, but I suspect that you are looking for a Table feature on the drawing. Not sure if this is possible in AutoCAD (I seem to recall that it is, but....). Quote Link to comment Share on other sites More sharing options...
zaphod Posted April 7, 2014 Share Posted April 7, 2014 Hi, I'm wondering if the above question is possible? Quote Link to comment Share on other sites More sharing options...
jalba Posted April 7, 2014 Author Share Posted April 7, 2014 I did come upon something about AutoParameter, but unable to find back the article (yet). Quote Link to comment Share on other sites More sharing options...
rkent Posted April 7, 2014 Share Posted April 7, 2014 What method did you use to change from dynamic to annotative? Your dimension doesn't look right in properties. The way to change dynamic to annotative is to select it and change the setting in properties, then the dims will still work in the parameter manager. I don't believe there is a way to show the parameter table on the drawing. Quote Link to comment Share on other sites More sharing options...
