Attributes Not Displaying in Properties Tab or Quick Properties
wpower12
I finally got some Lisp scripts working. They generate a block library from a CSV file. The script reads the file, and generates a simple rectangular block based on dimensions on the line. I have another script that can read a csv of block names and values, and add these as attributes to the block.
The attributes added are simple, like "weight" and "max stack qty". I would like to be able to see these values in the properties tab or in quick properties. In my CUI I have "Display Custom Attributes" checked under "block reference".
However, when I select a block, no attributes show up. I can get it to show me things like "name" and all of the scaling values, just no attributes.
I have tried to google this, but I havent anything that fixes the issue. I am using AutoCAD 2009.
Thank you.
