Findermb Posted June 11, 2013 Share Posted June 11, 2013 Hi there, I´m working with attribute blocks, and someone made an excel file with some data that has more than 1 line (That could be achieved pressing ALT+ENTER in excel) however when inserting the data with a coordinates MACRO, that attribute I can't edit those other lines of data, and when adding any information the other lines of data will be erased. Hope my hard english doesn't confuse you guys. Attached you can find both the excel and the .dwg the data is not the same, but the block has the same attributes EXAMPLE.xls example.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 12, 2013 Share Posted June 12, 2013 Can you post the macro as well, it might help someone figure it out, (but using the ALT+ENTER in Excel probably introduces special formatting codes which don't work in Autocad) it would be better to have the information in seperate cells in the Excel sheet. Quote Link to comment Share on other sites More sharing options...
Findermb Posted June 12, 2013 Author Share Posted June 12, 2013 Here is the MACRO, and I´m trying to separate the data, but there are over 15k of those blocks, and it will take me a long time to separate them manually. Coordenadas.zip Quote Link to comment Share on other sites More sharing options...
