Results 1 to 7 of 7
    Forum Newbie
    not specified
    Jul 2006
    6
    Default Scale not showing up in viewport options
    I just changed laptops. I used to always set the scale of my viewports using the properties dialog. Now when I select properties and a viewport I don't get this option (using 2004) Any ideas?
    Brad
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,193
    Is it a polygonal viewport that you are selecting? Polygonal viewports are actually two entities rolled into one, a polyline and a viewport. You have to specify which entity you want to get the properties of at the top of the properties palette. Select viewport and you will be able to set the scale.
    Or if the viewport is locked you will be able to see the scale of the viewport, but you won't be able to change it. Unlock the viewport and you will be able to set the scale.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Full Member
    not specified
    Jun 2006
    ATLANTA
    79
    I prefer to turn on the viewports toolbar. That way all you have to do is make the viewport active by double clicking inside then use the pulldown menu to choose the scale you want.
    Forum Newbie
    not specified
    Jul 2006
    6
    Default Very odd...
    Very odd. The scale dropdown wasn't coming up in the properties dialog. After I opened and closed the viewports toolbar, it started showing up.
    Thanks
  5. #5
    Forum Newbie
    AutoCAD 2008
    Oct 2008
    1
    Default Same
    I am having the same problem, except the properties palette will not even work for viewports. Usually when I select a viewport, the word "Viewport" appears in the selection drop-down box at the top of the properties palette. Now when I select any viewport, the drop-down is blank. It doesn't even have a "No selection" dialog in the box. Along with that, it is also missing most of the misc tools. I have attached two pictures showing what I have just explained. I can answer any additional detail questions, so please help.
    Note: both screenshots were taken while the palette had a viewport selected.
  6. #6
    Forum Newbie
    Civil 3D 2016
    Oct 2016
    1
    I guess that by this time you have already solved your problem but If any other may have the same problem I found on the autodesk official forum this:
    https://knowledge.autodesk.com/suppo...n-AutoCAD.html
    It seems to be related to Autodesk 360 not properly installed/unistalled.
  7. #7
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Not in 2006. A360 wasn't even a thing back then.
    Drafting is a breeze.
