mattCAD
I have a number of drawings with levels on (single line and multitext) which are currently set to a local datum and I need to amend all to ordnance datum. To help reduce the time involved to do this I am looking for lisp routine that can find levels which are to 3 decimal places and add a set figure to it. (ie add 0.57m to every level on the drawing.
Thanks for your help in advance
If I understand your question, for similar situations, I use this routine. Unknown to the author.
(defun chgterr (s)
  (if (/= s "Function cancelled")
     (princ (strcat "\nError: " s))
  (setq p nil)
  (setq *error* olderr)
(defun C:INC (/ p l n e os as ns st s nsl osl sl si chf chm olderr)
  (setq olderr  *error*
        *error* chgterr
        chm     0)
  (setq p (ssget))
  (setq inc (getreal "\nIncrement:"))
     (setq l 0 n (sslength p))
     (while (< l n)
        (if (= "TEXT"
               (cdr (assoc 0 (setq e (entget (ssname p l))))))
               (setq s (cdr (setq as (assoc 1 e))))
               (setq mn (atof s))
               (setq nm (+ mn inc))
               (setq s (rtos nm))
               (setq e (subst (cons 1 s) as e))
               (entmod e)
               (setq chm (1+ chm))
        (setq l (1+ l))
  (princ chm)
  (princ " text lines")
  (princ " changed.")
  (terpri)
(defun chgterr (s)
  (setq p nil)
        *error* chgterr
        chm     0)
  (setq p (ssget))
     (while (< l n)
        (if (= "TEXT"
               (setq mn (atof s))
               (setq s (rtos nm))
               (entmod e)
               (setq chm (1+ chm))
        (setq l (1+ l))
  (princ chm)
  (princ " changed.")
  (terpri)
This is a bit simpler, and supports 'undo' functionality:
(vl-load-com)
(defun c:FOO (/ *error* ss i acDoc)
 (defun *error* (msg)
   (if acDoc
     (vla-endundomark acDoc)
   (cond ((not msg))                                                   ; Normal exit
         ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
         ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
 (if (and (setq ss (ssget '((0 . "MTEXT,TEXT") (1 . "*#.#*"))))
          (setq i (getreal "\nEnter increment: "))
     (vla-startundomark
       (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
     (vlax-for x (vla-get-activeselectionset acDoc)
       (vla-put-textstring
         x
         (rtos (+ i (atof (vla-get-textstring x))) 2 3)
     (prompt (strcat "\n** " (itoa (sslength ss)) " object(s) modified ** ")
 (*error* nil)
Perfect that was exactly what I was looking for, Thanks for your help:)
For TEXT and MTEXT:
(defun chgterr (s)
  (setq p nil)
        *error* chgterr
        chm     0)
  (setq p (ssget '((0 . "TEXT,MTEXT"))))
     (while (< l n)
               (setq mn (atof s))
               (setq s (rtos nm))
               (entmod e)
               (setq chm (1+ chm))
              );progn
	(setq l (1+ l))
      ); while
  (princ chm)
  (princ " changed.")
  (terpri)
  );defun
For TEXT and MTEXT:
(defun chgterr (s)
  (setq p nil)
        *error* chgterr
        chm     0)
     (while (< l n)
               (setq mn (atof s))
               (setq s (rtos nm))
               (entmod e)
               (setq chm (1+ chm))
              );progn
	(setq l (1+ l))
      ); while
  (princ chm)
  (princ " changed.")
  (terpri)
  );defun
I sure hope the user always selects a valid selections set... Example: consider a TextString = "Bowties are cool".
