Results 1 to 8 of 8
    Forum Newbie
    Civil 3D 2013
    Jun 2013
    2
    Default Wierdness with rectangle command
    I have the following code to draw a fixed-width rectangle with the length of a given line:
    Code:
    (command "RECTANGLE" (list (car start)                          (- (cadr start) 0.33))
    	             (list (+ (car start) (distance start end)) (+ (cadr start) 0.33)))
    For some reason, though, the rectangles are starting at the line's start point rather than 0.33 units lower. My X and Y values are in the millions, in case that helps identify it as an overflow error.
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,247
    So what is the problem with that ?
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Thanks God, I'm far enough from Hitleropa
    1,697
    Try to take this code as basic,
    then add your changes to the variables
    Code:
    (defun C:MREC (/ dxf ang ang+  dis elist em_list end ln  pi_2 pts
    pt_lr pt_ur  start)
    (defun dxf (key alist)(cdr (assoc key
    alist)))
    (while
    (setq ln (entsel "\nSelect line:
     (setq ln (car
    ln)
           elist (entget
    ln)
           start (dxf 10
    elist)
           end (dxf 11
    elist)
           ang (angle start
    end)
           dis (distance start
    end)
           pi_2 (/ pi
    2.0)
           ang+    (+ ang
    pi_2)
     pt_ur    (polar end ang+
    dis)
     pt_lr   (polar start ang+
    dis))
           (setq pts (mapcar '(lambda(p)(list
    (car p) (cadr p)))
      (mapcar '(lambda(q) (trans q 1 0))(list start
    end pt_ur pt_lr))))
    (setq em_list
       (append
    (list
          '(0 .
    "LWPOLYLINE")
          '(100 .
    "AcDbEntity")
          '(100 .
    "AcDbPolyline")
          ;(cons
    8 "0"))
          (cons 90 (length
    pts))
          (cons 70
    1)
      (mapcar '(lambda
    (p) (list 10 (car p) (cadr p)))pts)
       (if (entmake em_list)
     (entupd
    (entlast))
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    This works fine for me:
    Code:
    ;; <snip>
    (if (and (setq start (trans (getpoint) 1 0))
             (not (initget 32))
             (setq end (trans (getpoint start) 1 0))
               (list (setq x (car start))
                     (- (setq y (cadr start)) 0.33)
                     (last start)
               (list (+ x (distance start end)) (+ y 0.33) (last end))
    ;; <snip>
    ** TRANS not required.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  5. #5
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,247
    Quote Originally Posted by BlackBox View Post
    But maybe off snap is required with the command call !
  6. #6
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by Tharwat View Post
    You mean "_non"? Sure if you like.
    [Edit] - Again, not required... The first point is the CENter of a circle.... Sorry, wrong thread.
  7. #7
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Sorry for my stupidity, perhaps like this
    Code:
    0))
              (not (initget
    32))
              (setq end (trans
       (command
    "RECTANGLE"
    "_non" (list (setq x (car
    start))
    0.33)
    (last
    start)
    "_non"(list (+ x (distance start end)) (+ y 0.33) (last end))
      (command "_rotate" "L" "" "_non" start (/ (* (angle start end) 180)
    pi)))
  8. #8
    Forum Newbie
    Civil 3D 2013
    Jun 2013
    2
    Adding "_non" did it! Thanks for the help.
  1. autoCAD wierdness
    By cadmoney in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Oct 2012, 01:43 am
  2. Replies: 2
    Last Post: 4th Oct 2010, 12:16 pm
  3. Polygon & Rectangle Command Doesn't Work
    By gsksun4 in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2010, 07:54 pm
  4. erase everything outside a rectangle - need command
    By mark.meyers in forum AutoCAD General
    Last Post: 6th Aug 2009, 04:42 pm
  5. Replies: 6
    Last Post: 16th Oct 2008, 01:06 pm
