Results 1 to 3 of 3
    Junior Member
    Construction
    jesskeene's Discipline Details
    Cad Technician
    Construction
    Storm drainage systems
    AutoCAD 2013
    Oct 2012
    Philadelphia, Pa
    15
    Default Paper Space dimensions are wrong
    I have been dimensioning my 3-D model in paper space, but my dimensions are wrong and I don't understand why. The height on this drawing attached was drawn as 3'-9" but everytime I try to dimension it in paper space it reads as 3'-3 1/4". And my width should be 2'-6" and it keeps reading as 1'-11 1/4". I have no idea where this came from, and I have double checked my work several times now, it was drawn correctly. And on top of all that, now that I have been messing with it, my dimension no longer changes to oblique the right way, I think I may have changed a setting along the way and made things worse. EEK! Can anyone see where I went wrong?
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Unfortunately, AutoCAD dimensions use only the XY coordinates of the pickpoints, Z is not factored, so while the actual 3D distance may be 2'-6", in your current view the distance in the XY plane is only 1'-11 1/4" Basically, you can not dimension 3D objects in Paperspace unless you create separate dimstyles for each plane that needs to be dimensioned, and apply a measurement scale factor (DIMLFAC) to account for the foreshortening.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Dimension in modelspace then the dims are correct and they look correct as well.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Dimensions not showing in paper space
    By Michelle E in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Jan 2014, 09:51 am
  2. Dimensions in Model space Vs Paper space
    By Abbyjay in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2013, 05:00 am
  3. Text, dimensions and notes in paper space
    By Cad Monkey 2 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Nov 2010, 08:53 pm
  4. Paper Space Scale question: What have I done wrong?
    By Mauser in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jun 2010, 10:55 am
  5. Dimensions in Paper Space
    By Bing in forum AutoCAD General
    Last Post: 2nd Feb 2007, 01:49 pm
Tags for this Thread
