Lisp routine doesn't work anymore
woohhoo
Hi guys
I just had an upgrade of Autocad 2010 to 2013. However, a very important lisproutine doesn't work properly anymore.
What has happened? Can someone help me please?
With the lisp I can select several arcs (not polylines!) and when I enter the length and the radius appeares above the selected lines.
ARCRLVOOR_DimVoorSnijden.lsp
Thx.
Below you find a sample. Could it be a wrong system variable property?
Everything is working normally here on that attached drawing .
Try the code on a new drawing .
Hope someone else try it as well to have more than one test on codes and drawing .
I tried the code on a new drawing and the result is the same. No values are shown :(.
I also hope that someone else want to try it.
Anyway, thx for your help.
:oops:Well, that was pretty dumb. I downloaded the DWG thinking I would take a look at it. But I was looking at the OP's "Using", totally ignoring he just upgraded!:lol: If you can dumb it down by saving it to the 2010 format or earlier, I can still take a look when I get a chance.:)
Doesn't work here on 2013 or 2014. I saved it down to 2004 but it still doesn't work in 2012 or 2011.
What language are you using for your OS. I have German, I know Dave has English but I'm not sure what Tharwat has.
Hi
Here is the 2010 version :)
sample_arc_error_2010.dwg
Thx
I have Windows and 7 and the language is English. My previous version of Autocad was 2010 and I worked with Windows XP.
New computer new version of Autocad and yet I've more problems as before :(
yep, English 2013 on Windows XP (16 bit obviously).
Perhaps this
(defun LM:GetObjectID ( doc obj )
 (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
   (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
   (itoa (vla-get-Objectid obj))
(setq id (LM:GetObjectID
              (vla-get-activedocument
                    (vlax-get-acad-object))
              arcobj))
(setq radstr (strcat "R=%<\\AcObjProp Object(%<\\_ObjId "
                    id
                    ">%).Radius \\f \"%pr2%lu2%ds44>%"))
(setq lenstr
          (strcat "\\PL=%<\\AcObjProp Object(%<\\_ObjId "
                  id
                  ">%).ArcLength \\f \"%ct8[1000]%pr0%lu2%ds44>%"))
Perhaps this
              arcobj))
                    id
(setq lenstr
                  id
Yes, problem solved!!
This works great. Thank you very much, pBe!!
:D
Also thx to everyone who worked on this problem too :thumbsup:
