Results 1 to 4 of 4
    Forum Newbie
    Revit 2013
    Jun 2013
    Acworth, GA
    Exclamation Is Revit the best program to make furniture pieces?
    Apologies in advance if this isn't in the most appropriate category.
    I recently started work at a marketing firm that was seeking people experienced in Revit. I used it a lot in school so I thought, awesome. When they told me more about the position, they told me I'd be using the software to create furniture pieces that'll go into rendered floorplans and their goal is for the pieces to look as real as possible in the rendering.
    Creating pieces wasn't something I did a lot of in my classes but I thought a challenge would be welcome. The problem is that I have one coworker who did very basic training in the software and that's it. No one else knows anything about Revit so I figured this is a good place to ask.
    I've found that tables are easy. Anything with edges, I'm fine with. But when pieces are supposed to have softer edges (like pillows, beds, chairs, etc) I'm having more trouble with making them.
    I've tried using the Model In Place option and the start from scratch option where I just go right into making a new component. It's a bit time consuming, but I'm hoping it's just because I'm new at it. I've even used the 3D Modeling part of AutoCAD 2013. It does make cushions easier but there's still some things I'm just not able to figure out.
    My main question is this: is it possible to make detailed/realistic furniture pieces for Revit (like things I would find on RevitCity) in Revit itself or should I use other AutoCAD software. The other two I've been looking at were Inventor or 3DS Max. I used Inventor a bit in classes for designing mechanical pieces and loved it. I've never used 3DS but I checked into it on YouTube and the videos show plenty of things I could use at work.
    Any helpful opinions on the matter would be greatly appreciated. I don't mind if I end up having to learn another program, as long as it makes things smoother and quicker in the long run.
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    I'm fairly certain that most Architects wouldn't want extremely 'Heavy' models in their BIM anyway! After all - it is Information modelling - not manufacturing modelling.
    Assuming then that you are just building this content for yourselves, and that it doesn't need to be parametric, then - yes, modelling in some other package and then importing would be much easier.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    This reminds me when I first started using Revit a few years ago. I was searching and searching for something that was very common and couldn't believe it couldn't be found. I forget exactly what it was. The next day I get a weekly email from one of those CAD rags. It had a long article about entourage families. Among the items were throw pillows. My head hit the desk. 3D throw pillows and they weren't free.
    Drafting is a breeze.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    tzframpton's Discipline Details
    BIM Specialist
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    You most certainly can use Revit for furniture modeling. The reason it's time consuming is because you simply are new to the program. I've seen Revit be used for phenomenal stuff. Check out the eBook Promo from Michael Anonuevo of www.littledetailscount.com
    In this promo he shows how detailed and great Revit can be utilized. Hopefully this can shine a light of hope in your ventures.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  1. Is there anyway to make a program make an edited dimension standout?
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th May 2015, 08:10 am
  2. I need help writing a program to make changes to a print.
    By lwm94 in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Nov 2012, 11:25 pm
  3. Furniture for 1:20 floorplan (2D furniture template)
    By nicnac01 in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2012, 07:11 pm
  4. Replies: 38
    Last Post: 9th Feb 2012, 02:55 am
  5. Guidance to make first program
    By russell84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Nov 2008, 08:13 am
Tags for this Thread
