hosyn Posted July 1, 2013 Share Posted July 1, 2013 I have in cad2014 laymrg .it dont act well . thre is th report action after run the command:: Command: LAYMRG Select object on layer to merge or [Name]: Selected layers: 0ROS. Select object on layer to merge or [Name/Undo]: Select object on target layer or [Name]: n Regenerating model. ** Glyph not defined at: \U+0054. ** Glyph not defined at: \U+0020. ** Glyph not defined at: \U+0046. ** Glyph not defined at: \U+0054. ** Glyph not defined at: \U+0020. ** Glyph not defined at: \U+0046. Command: Command: and i dont know how i can fix it? Quote Link to comment Share on other sites More sharing options...
rkent Posted July 1, 2013 Share Posted July 1, 2013 Have you tried the merge layer option in the layer manager (layerdlgmode needs to set to 1)? I am curious if you will get the same message. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 2, 2013 Share Posted July 2, 2013 I think that is a new option, rkent. I don't have a solution but this may help. "Glyph" is a symbol and "\U+00**" is Unicode used in text. My guess is that you got this file from an external source and there is a font in it that you don't have. Instead of using layer merge, can you just select the objects on that layer and change the layer designation? Quote Link to comment Share on other sites More sharing options...
rkent Posted July 2, 2013 Share Posted July 2, 2013 I think that is a new option, rkent. ... It is new in 2014, I am not sure what you are getting at. The OP says they are using 2014 in the post. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 2, 2013 Share Posted July 2, 2013 Oops sorry, his profile says 2011. That's what I thought he was using. My eyes weren't open enough, yet. BTW, I can't wait to use that new feature. Quote Link to comment Share on other sites More sharing options...
