Results 1 to 2 of 2
    Full Member 084x4larry's Avatar
    Structural
    084x4larry's Discipline Details
    steel detailer
    Structural
    AutoCAD 2012
    Aug 2012
    72
    Default mleader text problem
    ok, the text for my item balloons is on a layer that i need turned off so i need to change the layer the value inside the balloon comes out on.... anybody know how do this?
    "all I have is this piece of rock candy... but it's not for eatin', it's just for lookin' through"
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    This is kinda a guess.
    Select a mleader and open the Properties Palette. If there is a "Block" section near the bottom, note the block name. Use the Block Editor (BEDIT) to change the Attribute layer ( 0 is the default layer)
    ... or post a sample drawing with at least one mleader/balloon
  1. MLeader Text Justification Issue
    By Croweyes1121 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th May 2013, 12:15 am
  2. Help with mleader text
    By cso in forum AutoCAD General
    Last Post: 6th Apr 2013, 04:15 pm
  3. Why can't I see my text in MLEADER while typing?
    By bwalter1025 in forum AutoCAD General
    Last Post: 5th Apr 2012, 08:15 pm
  4. Getting mleader text to come in vertical
    By Michael83 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Oct 2010, 09:12 pm
  5. Mleader text frame
    By herb6874 in forum AutoCAD General
    Last Post: 16th Apr 2010, 02:23 pm
