TED Jordan Posted July 4, 2013 Share Posted July 4, 2013 Hi guys, For the life of me I can't remember how to do this so it doesn't ask for a block definition! I have an extruded region of 50 x 50 (SHS) that I want to put a 45 degree mitre on, so I orientate my UCS to ortho, I have a reference line drawn over the job for my 45 degree/3 points to pick... I Select 'both' to keep and it asks me for a block definition? Older versions have never asked me for this I'm certain and I'll had this before I just can't remember how to counter it - any clues? Jordan Quote Link to comment Share on other sites More sharing options...
nestly Posted July 4, 2013 Share Posted July 4, 2013 Welcome to Cadtutor. AutoCAD can't slice a block, and it can't slice with a block, so message seems rather confusing. Can you post the text from the Text Window (F2) after trying to SLICE. This is what it should look like when using SLICE with the 3point option. Command: slice Select objects to slice: 1 found Select objects to slice: Specify start point of slicing plane or [planar Object/Surface/Zaxis/View/XY/YZ/ZX/3points] <3points>: 3p Specify first point on plane: Specify second point on plane: Specify third point on plane: Specify a point on desired side or [keep Both sides] <Both>: Quote Link to comment Share on other sites More sharing options...
TED Jordan Posted July 4, 2013 Author Share Posted July 4, 2013 Thanks for replying nestly. I feel like a noob - spent the past hour or so trying to figure it then realised whereas I was used to having to give three reference points then typing 'B' as long as the UCS is orientated correctly so my x/y plane is at 90 degrees to my splice plane it'll slice along the first two points. I wasn't taking notice that once I'd clicked the second point it was prompting me to keep both sides or choose one to keep, and clicking a third point, which by then had cancelled the slice command and when I then typed 'b' for 'both sides' it was on a fresh command being..... block definition. doh... Jordan Quote Link to comment Share on other sites More sharing options...
nestly Posted July 4, 2013 Share Posted July 4, 2013 It happens... sometimes the mind gets locked into a certain sequence... and the obvious is overlooked. Referring to the command line (text window) is usually a good way to see where the sequence is failing. Quote Link to comment Share on other sites More sharing options...
TED Jordan Posted July 4, 2013 Author Share Posted July 4, 2013 You aren't wrong there on both accounts! Thanks for the help anyway Jordan Quote Link to comment Share on other sites More sharing options...
