Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2005
    Jul 2013
    2
    Default HELP:Autocad scale/print
    Hey i need some help with autocad...i use autocad 2005(we use this version in college).I have on a paper a 1:100 drawing which i should draw it in autocad on 1:50 scale.i finished the drawing but i have to print it also what should i do??..note:i did not change mm to meters from units..i must do it again from the beginning? Thank you!
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Welcome to Cadtutor, Bill
    In AutoCAD, you should draw everything 1:1 Scaling takes place when you print/plot. However, even if you did not draw it 1:1 in Autocad, you will NOT have to redraw anything as long as you were consistent when transferring the measurements from the paper drawing into AutoCAD.
    It would be easiest if you could attach the portion of the .dwg file that you have competed, and perhaps even a scan of the paper drawing, and any specific instructions you were given.
    Forum Newbie
    AutoCAD 2005
    Jul 2013
    2
    Ok i attached the drawing...its ok i just want to convert it to 1:50 so i can print it.
    (the only thing that has to be printed is that small ground floor plan only).
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Let me qualify this by saying that I never work in metric, but it appears to me that your house is only 12.5mm x 8.35mm. I would use the SCALE command to increase the size by a factor of 1000, then create a fresh layout, make a new viewport, set the scale to 1:50 from the Viewports toolbar, and print (A4 paper will be just big enough for the floorplan at 1:50 scale)
    Again, having little to no experience with metric drawings, and not knowing exactly what your assignment is, here's a 2 minute video that takes the drawing from it's current state to being ready to send to the printer 1:50 on A4 paper (AutoCAD2005) ---> http://www.screencast.com/t/99wQsiaxA
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Quote Originally Posted by nestly View Post
    It could also be interpreted that the drawing units were metres, and the Drag-and-drop scale had not been changed from the default of Millimeters.
  6. #6
    Forum Newbie
    Civil 3D 2013
    Dec 2015
    7
    What I use so as not to be confused
    https://www.youtube.com/watch?v=u4VuPnRLgk4
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    slymper: Just joined and all you have done so far is pull up past threads to post links. Something is not quite right me thinks.
  1. How to print a pdf in the right scale from autocad
    By wandsworth in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2012, 08:21 pm
  2. Print to scale
    By danav in forum AutoCAD General
    Last Post: 12th Jul 2009, 05:36 pm
  3. Print on scale
    By ALoock in forum AutoCAD Beginners' Area
    Last Post: 1st Apr 2009, 12:30 pm
  4. print in scale
    By Kari in forum Revit General
    Last Post: 20th Mar 2009, 06:46 am
  5. scale in print
    By cadbaby in forum AutoCAD General
    Last Post: 19th Feb 2005, 06:22 am
