Results 1 to 5 of 5
    Forum Newbie
    not specified
    Jul 2006
    4
    Default Show grid Lines??
    Is there any way to show the "grid" lines that stand for each unit so i could have an easier time drawing to scale... If not what the easiest way I could draw object to a scale on one unit=one inch.
    Yes I am new to autocad and its version 2005
    Thanks in advance
    Forum Newbie
    not specified
    Jul 2006
    4
    Wow dont all jump at once to help out....
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You shouldn't draw to "grid lines" as a visual aid, you won't be using the accuracy availble, you may as well draw on paper.
    Obtain accuracy by specifying dimensions on input, offsetting, many other tools to draw "exactly". If drawing to even inches then I suppose using "snap" and "grid" wouldn't hurt but that (to me) is just cumbersome.
    When drawing a line you can draw an exact length at 0/90 degrees by having 'ortho' on, cursor in direction, just enter the distance to the next point. For drawing a line at any angle use "distance<angle" format. Lots of other ways to help draw efficiently/accurately.
    Full Member
    not specified
    Jul 2006
    London UK
    55
  5. #5
    Senior Member Groutie's Avatar
    Groutie's Computer Details
    i7 3.6 GHz
    32Gb
    Quadro 4000 2Gb
    AutoCAD 2013
    Jun 2006
    London
    127
    Drawing to scale in AutoCAD????????????????
    Most confusing.
    You draw 1:1 in AutoCAD, that's the whole point. You then output (print) to ANY required scale, or perhaps even N.T.S. If you're drawing has been dimensioned, technically you don't need to produce a scaled copy in some cases.
    Interesting question.
