Results 1 to 2 of 2
    Full Member Luís Augusto's Avatar
    Electrical
    Luís Augusto's Discipline Details
    Designer / Planner
    Electrical
    Manufacture of electrical harnesses
    AutoCAD 2010
    Apr 2012
    Botucatu, SP, Brazil
    80
    Default Routine modification Dims2Field
    In looking for a lisp routine that performs the sum selected dimensions, found one that I believe to be ideal for my work.
    Could the author or another member of the forum to make a change?
    It would be ideal for me to make the sum property>%). TextOverride>% Rotated Dimension object.
    I tried to make the change but as I am not aware that language still did not succeed. Returns the error "misplaced dot on input".
    Below the original routine.
    Dims2Field.lsp
    Code:
    (defun c:Dims2Field ( / *error* spc doc pt uFlag ss ids )
    (vl-load-com)
    ;; © Lee Mac 2010
    (defun *error* ( msg )
    (and uFlag (vla-EndUndomark doc))
    (princ (strcat "\n** Error: " msg " **")))
    (setq spc
    (if
    (or
    (eq AcModelSpace
    (vla-get-ActiveSpace
    (setq doc
    (vla-get-ActiveDocument
    (vlax-get-acad-object)
    (eq :vlax-true (vla-get-MSpace doc))
    (vla-get-ModelSpace doc)
    (vla-get-PaperSpace doc)
    (if (and (ssget '((0 . "*DIMENSION")))
    (setq pt (getpoint "\nPick Point for Field: ")))
    (setq uFlag (not (vla-StartUndoMark doc)))
    (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
    (setq Ids
    (cons (GetObjectID obj doc) Ids)
    (vla-delete ss)
    (vla-AddMText spc (vlax-3D-point pt) 0.
    (if (= 1 (length Ids))
    (strcat "%<\\AcObjProp Object(%<\\_ObjId " (car Ids) ">%).Measurement \\f \"%lu6\">%")
    (strcat "%<\\AcExpr"
    (lst->str Ids " %<\\AcObjProp Object(%<\\_ObjId " ">%).Measurement >% +")
    ">%).Measurement >% \\f \"%lu6\">%"
    (setq uFlag (vla-EndUndomark doc))
    (defun lst->str ( lst d1 d2 )
    ;; © Lee Mac 2010
    (if (cdr lst)
    (strcat d1 (car lst) d2 (lst->str (cdr lst) d1 d2))
    (strcat d1 (car lst))
    (defun GetObjectID ( obj doc )
    ;; © Lee Mac 2010
    (if
    (eq "X64"
    (strcase
    (getenv "PROCESSOR_ARCHITECTURE")
    (vlax-invoke-method
    (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false
    (itoa (vla-get-Objectid obj))
    Thank in advanced.
    Luis Augusto.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    We'll give this thread a *bump* and see if it draws any response. Good luck.
  1. Little modification to this Lisp.
    By Saqib_theleo in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Nov 2012, 04:49 pm
  2. Need little modification for this lisp
    By cadamrao in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jul 2012, 04:53 am
  3. Modification of LISP
    Last Post: 3rd May 2010, 10:04 am
  4. Ellipse Modification
    By JCAMP17 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Dec 2008, 08:57 pm
  5. Command modification
    By johnengineer in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2007, 06:18 pm
Tags for this Thread
