Luís Augusto Posted July 5, 2013 Share Posted July 5, 2013 In looking for a lisp routine that performs the sum selected dimensions, found one that I believe to be ideal for my work. Could the author or another member of the forum to make a change? It would be ideal for me to make the sum property>%). TextOverride>% Rotated Dimension object. I tried to make the change but as I am not aware that language still did not succeed. Returns the error "misplaced dot on input". Below the original routine. Dims2Field.lsp (defun c:Dims2Field ( / *error* spc doc pt uFlag ss ids ) (vl-load-com) ;; © Lee Mac 2010 (defun *error* ( msg ) (and uFlag (vla-EndUndomark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq spc (if (or (eq AcModelSpace (vla-get-ActiveSpace (setq doc (vla-get-ActiveDocument (vlax-get-acad-object) ) ) ) ) (eq :vlax-true (vla-get-MSpace doc)) ) (vla-get-ModelSpace doc) (vla-get-PaperSpace doc) ) ) (if (and (ssget '((0 . "*DIMENSION"))) (setq pt (getpoint "\nPick Point for Field: "))) (progn (setq uFlag (not (vla-StartUndoMark doc))) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (setq Ids (cons (GetObjectID obj doc) Ids) ) ) (vla-delete ss) (vla-AddMText spc (vlax-3D-point pt) 0. (if (= 1 (length Ids)) (strcat "%<\\AcObjProp Object(%<\\_ObjId " (car Ids) ">%).Measurement \\f \"%lu6\">%") (strcat "%<\\AcExpr" (lst->str Ids " %<\\AcObjProp Object(%<\\_ObjId " ">%).Measurement >% +") ">%).Measurement >% \\f \"%lu6\">%" ) ) ) (setq uFlag (vla-EndUndomark doc)) ) ) (princ) ) (defun lst->str ( lst d1 d2 ) ;; © Lee Mac 2010 (if (cdr lst) (strcat d1 (car lst) d2 (lst->str (cdr lst) d1 d2)) (strcat d1 (car lst)) ) ) (defun GetObjectID ( obj doc ) ;; © Lee Mac 2010 (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE") ) ) (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false ) (itoa (vla-get-Objectid obj)) ) ) Thank in advanced. Luis Augusto. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 8, 2013 Share Posted July 8, 2013 We'll give this thread a *bump* and see if it draws any response. Good luck. Quote Link to comment Share on other sites More sharing options...
