Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Full Member Luís Augusto's Avatar
    Electrical
    Luís Augusto's Discipline Details
    Designer / Planner
    Electrical
    Manufacture of electrical harnesses
    AutoCAD 2010
    Apr 2012
    Botucatu, SP, Brazil
    80
    Default Select associated objects a field autocad
    Hi guys, is there any command that performs the selection of objects associated with an object field?
    I'm using an excellent routine performed by Lee Mac to make the sum of texts. At the end of addition, it generates a field.
    In some moments I need to check the path where I spent. It would be very interesting if we could make a quick selection using the ID of the objects contained in the field.
    I should point out that I still have no experience with the Lisp language.
    Thank in advance.
    Luis Augusto.
    Currently with autocad 2010
    Translated by google
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    You'll need to first parse the FieldCode string, and then iterate the appropriate Block Object given the ObjectId extracted.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
    See this old program:
    http://www.theswamp.org/index.php?topic=39951
    [ membership may be required ]
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    My try ...
    Code:
    (defun c:Test (/ ss i sn fd cd l s sad j e p n)
    ;;;        --=={ Tharwat 07. 07. 2013 }==--    ;;;
    ;;; Function to select the related Texts to a field     ;;;
      (if (progn
            (princ "\n Select field Text :")
            (setq ss (ssget "_+.:S" '((0 . "MTEXT"))))
          (setq sn (ssname ss (setq i (1- i))))
          (if (setq fd (vla-fieldcode (vlax-ename->vla-object sn)))
            (while
              (setq cd (vl-string-search "%<\\_ObjId " fd))
               (setq l  (cons (atoi (substr fd (+ cd 11) 10)) l)
                     fd (substr fd (+ cd 11))
      (if
        (and l
             (setq
               s (ssget "_X"
                        (list '(0 . "TEXT,MTEXT") (cons 410 (getvar 'ctab)))
           (setq sad (ssadd))
           (repeat (setq j (sslength s))
             (setq e (ssname s (setq j (1- j))))
             (if (member (vla-get-ObjectID (vlax-ename->vla-object e)) l)
               (ssadd e sad)
      (if (and sad (> (sslength sad) 0))
          (setq p (cdr (assoc 10 (entget (ssname ss 0)))))
          (repeat (setq n (sslength sad))
            (grdraw p
                    (cdr (assoc 10 (entget (ssname sad (setq n (1- n))))))
                    2
                    1
    (vl-load-com)
  5. #5
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Quote Originally Posted by BlackBox View Post
    You'll need to first parse the FieldCode string, and then iterate the appropriate Block Object given the handle (ObjectId) extracted.
    Dear BlackBox, thanks for the reply. Unfortunately still can not create my own codes. Hopefully soon get.
    Quote Originally Posted by Lee Mac View Post
    Lee, thanks for helping me again. Unfortunately I still have no access to www.theswamp.org. I sent an email to Mark to get access.
    Quote Originally Posted by Tharwat View Post
    My try ...
    Code:
      (if (progn
            (while
      (if
        (and l
             (setq
               s (ssget "_X"
           (setq sad (ssadd))
               (ssadd e sad)
            (grdraw p
                    2
                    1
    (vl-load-com)
    Tharwat, thanks for your reply.
    Unfortunately, the program did not work on my machine here, also did not return error.
    I am attaching the design to perform a test.
    I appreciate everyone's attention.
    SUM.dwg
    Luis Augusto.
  6. #6
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Star
    Beautiful job Lee.
    Congratulations. Not even in a dream could imagine something so perfect for my situation.
    This routine is fantastic, I run the commands zoom and pan, temporary lines keeps the same way.
    Surely the program will greatly improve my work.
    I can post the code for others with the same need to see the solution?
    Thank you all.
    Best regards,
    Luís Augusto.
  7. #7
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Quote Originally Posted by Luís Augusto View Post
    Luis Augusto.
    That's odd , I tried the code on Cad 2010 and 2013 and it works well .
    The routine ask you to pick on field string then it will draw a vector line to the related text entities to that field .
    Are you using my code separately or you are adding them to another codes ?
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,600
    Beautiful job Lee.
    That's fantastic to hear, thank you for your kind compliments Luís!
    I'm delighted that the program will be useful in your work.
    I have now attached the program to this post for those without access to the Swamp.
  9. #9
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Tharwat, I do not dare to change codes. I am trying to understand so many parentheses.
    Tomorrow i will test your routine on other machines and give you feedback.
    I believe that the forum users here could do the same, thus we would have two solutions.
    Thanks for disposal.
    Best Regards, Luis Augusto.
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    I will be waiting for that test
    Thank you .
  1. AutoCAD Pick Points and Select Objects
    By chickenjoe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2012, 06:25 am
  2. I have to shift-select to select multiple objects
    By PDS in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2011, 08:15 pm
  3. Select By Selection Set Name, on 'Select Objects:' prompt
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2011, 10:28 am
  4. Use Quick Select to select objects in your AutoCAD drawing
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 16th Mar 2011, 04:29 pm
  5. Quickly select objects with Quick Select
    Last Post: 23rd Dec 2007, 01:13 am
Tags for this Thread
