Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    That's pretty schnazzy, Lee
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  2. #12
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,573
    Quote Originally Posted by BlackBox View Post
    Cheers BB
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  3. #13
    Full Member Luís Augusto's Avatar
    Electrical
    Luís Augusto's Discipline Details
    Designer / Planner
    Electrical
    Manufacture of electrical harnesses
    AutoCAD 2010
    Apr 2012
    Botucatu, SP, Brazil
    80
    Quote Originally Posted by Tharwat View Post
    I will be waiting for that test
    Thank you .
    How will you Tharwat?
    As promised, I tested the program on three machines. Two OS with 32bits and 64bits another.
    There is a limitation in 64bit OS. With 32bit OS works very well. I really liked the fact that you can select other fields and keep the old temporary line.
    Another observation is how to zoom and pan commands eliminate these temporary lines, the lines would be desirable to remain until press any key.
    You can make these improvements?
    Thank you for sharing your work with us.
    Big hug.
    Luis Augusto.
    Translated by google
  4. #14
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,227
    Quote Originally Posted by Luís Augusto View Post
    Thanks for keeping the promise and please try this modified code and let me know .
    Code:
    (defun c:Test (/ *error* ss i sn fd cd l s sad j e p n lst)
    ;;;       ---===={ Tharwat 07. 07. 2013 }====---    ;;;
    ;;; Function to select the related Texts to a field     ;;;
      (defun *error* (x) (redraw) (princ "\n*Cancel*"))
      (if (progn
            (princ "\n Select field Text :")
            (setq ss (ssget "_+.:S" '((0 . "MTEXT"))))
          (setq sn (ssname ss (setq i (1- i))))
          (if (setq fd (vla-fieldcode (vlax-ename->vla-object sn)))
            (while
              (setq cd (vl-string-search "%<\\_ObjId " fd))
               (setq l  (cons (atoi (substr fd (+ cd 11) 10)) l)
                     fd (substr fd (+ cd 11))
      (if
        (and l
             (setq
               s (ssget "_X"
                        (list '(0 . "TEXT,MTEXT") (cons 410 (getvar 'ctab)))
           (setq sad (ssadd))
           (repeat (setq j (sslength s))
             (setq e (ssname s (setq j (1- j))))
             (if (member (vla-get-ObjectID (vlax-ename->vla-object e)) l)
               (ssadd e sad)
      (if (and sad (> (sslength sad) 0))
          (setq p (cdr (assoc 10 (entget (ssname ss 0)))))
          (repeat (setq n (sslength sad))
            (setq
              lst (cons
                    (cdr (assoc 10 (entget (ssname sad (setq n (1- n))))))
                    lst
          (while (eq (car (grread t 15 0)) 5)
            (princ "\r Press any key to exit :")
            (foreach x lst
              (grdraw p x 2 1)
          (redraw)
    (vl-load-com)
  5. #15
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Quote Originally Posted by Lee Mac View Post
    That's fantastic to hear, thank you for your kind compliments Luís!
    I'm delighted that the program will be useful in your work.
    I have now attached the program to this post for those without access to the Swamp.
    Attachment 42816
    Hello Lee
    Do not want to seem abused, but I was very curious.
    I am using this routine to check the way I did when I add the length of a cable layout for an electric whip.
    Our colleague fixo is helping me with a routine to facilitate the completion of the table From / To. The program will generate a calculated field within the table.
    When accessing a FIELD within the table, it is a bit strange the line from the origin, so I had the following idea.
    It would be possible to change the program so that the selection of the FIELD, the source was not the text but a block with the name "NewOrigin" in the center of the layout?
    Luis Augusto.
    Translated by Gloogle
  6. #16
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,573
    When accessing a FIELD within the table, it is a bit strange the line from the origin...
    Hi Luís,
    I hadn't tested the program with fields located within table cells, but will look to resolve this issue when I get some spare time to work on the program.
    Lee
  7. #17
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Hi Luís,
    Lee
    Hi Lee,
    I think I did not express myself well.
    I believe that in my case, a block as the source, would be an excellent solution for the type of work I do. In certain situations, my list of cables may be too far from the layout of the electrical harness.
    I plan to deploy your code after the sum of the cables. At this time, IDobjects must be in program memory yet. Thus the existing function would direct origin of the lines to the block NewOrigin. That way I can make the conference the way immediately.
    Sorry for the misunderstanding.
    Regards, Luis Augusto.
    Translated by gloogle
  8. #18
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Hello Tharwat.
    Sorry for the delay, I not had the opportunity to test before.
    I installed VirtualBox on my machine. Now I can test code for 32bit OS.....
    That's it, your code works perfectly, however, with the last review, he missed an interesting feature, which was to select multiple objectFIELDS. No problem.
    Congratulations my friend, I hope to one day be able to write my own code too.
    Best regards, Luís Augusto.
  9. #19
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,227
    Thank you for your test and for following your promises with it , it is much appreciated .
    Don't worry , you'd write your own codes if you insist on learning and working on programming daily , and I wish you best of luck .
    Tharwat
  10. #20
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    See this old program:...
    Excellent idea Lee. Me like it muchísimo.
  1. AutoCAD Pick Points and Select Objects
    By chickenjoe in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th May 2012, 06:25 am
  2. I have to shift-select to select multiple objects
    By PDS in forum AutoCAD Beginners' Area
    Last Post: 29th Nov 2011, 08:15 pm
  3. Select By Selection Set Name, on 'Select Objects:' prompt
    By harilalmn in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2011, 10:28 am
  4. Use Quick Select to select objects in your AutoCAD drawing
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 16th Mar 2011, 04:29 pm
  5. Quickly select objects with Quick Select
    Last Post: 23rd Dec 2007, 01:13 am
Tags for this Thread
