Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 59
  1. #11
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    In the following example, how would I use DSVIEW to select all the circles, but not the rectangles? As far as I can tell, objects that are windowed, but not in the main display are not included in the selection set, just like using the built in transparent zoom/pan
  2. #12
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Why not select all of them while you are zoomed out and then zoom in to deselect the one(s) that you don't want?
    Drafting is a breeze.
  3. #13
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    DeSelect the how? By zooming in close enough to be able to shift-select each rectangle without accidentally selecting circle? There are 20 columns of circles/rectangles in my example... what if there were 100 or 1000?
  4. #14
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Setting PICKDRAG to 1 and picking the circles individually would work but it would also be more of a PITA.
    I used the feature back when it was solely an exclusive feature of graphics cards and software produced by a company called nth Engine. However AutoDesk bought them out and decided to start messing with it (i.e.- they screwed it up). I continued to use it for a couple of years afterwards then finally gave up.
    Update.
    Using AutoCAD 2014 where PICKDRAG can be set to 2 also does not work. Guess it is back to the think tank. Sorry about that guys.
  5. #15
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by nestly View Post
    I was responding to the OPs question. It just so happened that you posted while I was typing and it looked like I was responding to you. He is using fence selection on an column of 100 objects trying to get 98 of them. I'm saying select all of them and deselect using his preferred method.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Interesting. Actually it does work in an odd sort of way. The user would have to zoom in and build individual selection windows around all the circles he/she could see at one time on their screen then change the view (via the aerial view) to another portion of their screen and do it again. This is not how it worked when nth Engine designed the program. Trivia: nth Engine was located in Texas. The software required a dongle. The cost of an nth Engine graphics card with the aerial viewing software was $3000. This was back in 1985.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    OK...confirmed using AutoCAD 2014.
    My test was a similar rectangle and circle that I arrayed in 12 columns and 12 rows (144 rectangles/circles). I ran the test using the Move command.
    Using the aerial viewer I zoomed in on the four bottom rows and built individual windows around the circles in each of the first three rows (a window captured 12 circles). Switched my view so I could see the top four rows and did the same thing for three of the four. So now I had selected selected 3x12x2 or 72 circles. Finished the Move command by dragging everything way off to one side. All 72 circles came along for the ride.
    Bottom line. It works but you need a certain "technique" to get the desired results. Is it perfect? Probably not but it will do in a pinch.
  8. #18
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    @ Rob, thanks for the clarification.
    I generally agree that objects that are scrolled off screen should not be included.. It's a safety feature to help users avoid inadvertently modifying objects they didn't realize they selected, but there also should be a way to override this behavior.
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I can replicate the same behavior without using the aerial view just relying on my scroll button to zoom in and out of my drawing. Variables set as follows:
    PICKFIRST=1
    PICKADD=2
    PICKDRAG=0
  10. #20
    Junior Member
    AutoCAD 2011
    Feb 2010
    Montreal
    13
    Quite primitive way but it works.
    Draw rectangular around objects, then zoom out and select within borders. Can you PLine to see it better.
  1. Zoom extents and Zoom Windows
    By FELIXJM in forum .NET, ObjectARX & VBA
    Last Post: 4th Sep 2012, 03:53 am
  2. zoom extends doesn't zoom completely (hidden objects issue)
    By khoshravan in forum AutoCAD General
    Last Post: 4th Jul 2011, 06:21 am
  3. Replies: 1
    Last Post: 18th Nov 2010, 01:56 pm
  4. Strange bug: Scroll mouse zoom out or ZOOM OUT
    By Martin Carmona in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 11:42 pm
