Joining different wire types...
pqphillips
Okay guys...
I'm working on a system where I have power coming out of a device and hitting a busbar. I have the busbar as a separate layer and have added it as a wire type to the system.
The issue I have is having it come out the device as a regular wire and attach to the busbar. When I do this, ACADE switches the wire to be on the busbar layer.
Anyone know how to alleviate this?
I'm guessing that Change All Wire(s) in the Network is currently enabled right? What if you were to disable it?
can the busbar be defined as a terminal rather than a wire?
I'd rather not do that...
That did it! I had to manually select all the segments and crossover loops, but it worked! Thanks, man!
