Results 1 to 4 of 4
    Junior Member
    Map 3D 2012
    Jul 2013
    Arkansas
    11
    Default lisp to export the handles and the x, y coordinates for a polyline
    I will try to explain this the best I can. I have several hundred miles of aerial and buried fiber. It is in AutoCAD map 3d 2012. I was given the task to create a database that links to the drawing and consists of information extracted from attributed blocks and cable information. The blocks are no problem. I am able to get all the info needed from ATTOUT, but getting the fiber info can be done manually. The cable in the landbase (.dwg) is represented by polylines and the access database links to the handle created by autocad. I can get all the handles and then manually type the pole to pole info. But if I can export the handle with the start and end coordinates it would be a much faster process. I have tried using the dataexport command but I cant seem to get the handle information. or if there is a way to export all attributed block info and polyline handles with start and end location at the same time, would be more of a time saver. Any help would be greatly appreciated.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,713
    Am I missing something I provide a soloution to this exact question about 6 months ago
    It pays to search first. Try "Handle" as key word.
    Junior Member
    Map 3D 2012
    Jul 2013
    Arkansas
    11
    I think I'm missing something. I have searched for the answer for a week now and have tried the lisps but either didn't get the results or got an error.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Then try mentioning what you have tried so far and why they didn't work and the errors you recieved. Keeps everyone from guessing.
  1. Replies: 22
    Last Post: 27th Jul 2013, 03:54 am
  2. Export coordinates and blockname to excel
    By Wouter543 in forum AutoCAD Beginners' Area
    Last Post: 21st Mar 2012, 03:28 pm
  3. Replies: 10
    Last Post: 13th Jul 2011, 01:51 pm
  4. Export Coordinates from AutoCAD Help
    By Kcks in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2010, 11:25 am
  5. How can I export X, Y coordinates of objects??
    By acatalin2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2005, 07:32 pm
Tags for this Thread
