Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    I did not recognize that fact. My apologies. Thanks for enlightening me.
  2. #12
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    No worries
  3. #13
    Forum Newbie
    AutoCAD LT 2011
    Jul 2013
    5
    Great, this is what I was looking for. However, for some reason I am getting an error in the pattern when attempting to use it. Thoughts?
    Thanks for your help!
  4. #14
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    Add a blank line to the end of the file? Copy everything between the == do not include ==== lines below into the .PAT file.
    - or try the attachment (remove the .txt extension to save as a .PAT file).
    *RANDOMHORIZONTAL2-12,200 units with lines spaced between 2 and 12 apart
    ; Pattern written by HatchKit v2.7 Hatch Pattern Editor
    ; HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013.
    ; www.hatchkit.com.au
    ;-Comment =CadTutor
    ;-Template=NEW,
    ;-Source =C:\Users\hugh\Desktop\RANDOMHORIZONTAL2-12.PAT
    ;-Date =12/07/2013
    ;-Time =9:43:30 PM
    ;-HatchKitVersion=2.7.1.1995
    0,0,195,0,200
    0,0,189,0,200
    0,0,180,0,200
    0,0,172,0,200
    0,0,163,0,200
    0,0,152,0,200
    0,0,140,0,200
    0,0,132,0,200
    0,0,124,0,200
    0,0,117,0,200
    0,0,111,0,200
    0,0,108,0,200
    0,0,101,0,200
    0,0,96,0,200
    0,0,90,0,200
    0,0,84,0,200
    0,0,78,0,200
    0,0,73,0,200
    0,0,71,0,200
    0,0,63,0,200
    0,0,54,0,200
    0,0,43,0,200
    0,0,39,0,200
    0,0,36,0,200
    0,0,28,0,200
    0,0,20,0,200
    0,0,11,0,200
    0,0,8,0,200
    0,0,0,0,200
    === do not include ===
  5. #15
    Forum Newbie
    AutoCAD LT 2011
    Jul 2013
    5
    It was a blank line causing the issue, this works perfectly now. Thank you so much for the pattern and clarifying modifications to it Hugha!
  6. #16
    Forum Newbie
    Architectural
    Revit 2016
    Jul 2017
    4
    Hi all,
    Follow up question- I am trying to do a similar thing as the original poster, but in Revit. I'm learning about creating custom hatches/ .pat files, but it isn't quite working for me. I am able to load a custom hatch and all, but that doesn't quite fit the bill. We are trying to use a hatch to show a series of corrugated metal panels that vary (seemingly randomly) across the building; i.e. 12", 2" reveal, 6", 6" reveal, 8", 6" reveal, etc. Horizontal lines every 10' only.
    I tried loading the above (converted to vertical lines), but it seems like revit is only using the first two lines??
    This would really help me out, as what we are currently doing is using a bunch of drafting lines in the elevations to mimic this corrugation, and that has to be redone manually! It's super inefficient!
    Thanks!
  7. #17
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    Hi Edar,
    you can build any "Simple" pattern of unbroken lines with the free HatchKit Add-In for Revit available from the [Revit App Store].
    Here's its online help. Select "new" then "simple" then add llnes with Angle set to zero at nominated points all spaced at a distance equal to the sum of all individual panel and reveal widths.
    E.g: for the sizes you mentioned that overall spacing would be 12"+ 2" + 6" + 6" + 8" + 6" = 40".
    hth
    Hugh
  8. #18
    Forum Newbie
    Architectural
    Revit 2016
    Jul 2017
    4
    Thanks hugha! I struggled through and was able to type out a new hatch in the .pat file. I do have a couple more questions about it, though:
    Where is (0,0) in the revit file? Is 0 where the material starts? At level 1? Or at the actual revit origin (so if the Level 1 is at +309.80 feet is that the actual 0 Y point)?
    I've attached a clip. I'm trying to get the breaks (every 10') to align with the actual break height (drawn in detail lines). So far Y=0 and Y=19 and Y=137 (11'-5") don't work.
    Also, sometimes a hatch that does work won't appear in the import list. I've tried saving-as with the pat files, but I can't figure out the pattern there.
    Thanks!!
  9. #19
    Forum Newbie
    Architectural
    Revit 2016
    Jul 2017
    4
    Quote Originally Posted by edar View Post
    I think I've answered my own question. I set Y to the absolute height in revit, and it just took a little nudging from there. Please let me know if that's not how you understand it to work.
    THanks!
  10. #20
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    That's how I understand it works. An expert may be able to shed more light.
    The import won't let you choose a problematical hatch. Something's wrong. Post an example for dissection
  1. Line spacing for TEXT
    By darrellk-1 in forum AutoCAD General
    Last Post: 12th Jun 2010, 08:29 pm
  2. Custom Line Type Spacing
    By Proctor in forum AutoCAD General
    Last Post: 21st May 2010, 06:16 pm
  3. Text Line Spacing
    By ankers in forum AutoCAD General
    Last Post: 12th Aug 2009, 02:33 pm
  4. Random Stone Hatch
    By Simple153 in forum AutoCAD General
    Last Post: 18th Apr 2009, 02:02 am
  5. MText line spacing
    By Alan Cullen in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2006, 10:24 pm
