gotchy Posted July 13, 2013 Share Posted July 13, 2013 I need to draw a couple of hidden lines into a drawing. I see that it is not in my database when I go to Modify/Properties, it does not exist. I am a beginner and I am using either v 2000, or v 2007 if it matters. Thank you, Gotchy Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 13, 2013 Share Posted July 13, 2013 Type LTSTYLE at the command line then hit ENTER. LOAD will show you a drop down list of about a zillion different line types. Choose the one you want. Quote Link to comment Share on other sites More sharing options...
nestly Posted July 13, 2013 Share Posted July 13, 2013 What Dadgad said... plus if if you frequently need a linetype, make sure it's in your template by using the previously described method, then resave the template. If you have another drawing with the linetype, you can also drag/drop or copy/paste an object with that linetype, and the linetype of the objects also comes into the drawing. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 13, 2013 Share Posted July 13, 2013 Should you not have permission(s) to modify your template, you can STEAL what you need from another drawing/template, thanks to Lee. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 14, 2013 Share Posted July 14, 2013 What Dadgad said... plus if if you frequently need a linetype, make sure it's in your template by using the previously described method, then resave the template. If you have another drawing with the linetype, you can also drag/drop or copy/paste an object with that linetype, and the linetype of the objects also comes into the drawing. I very rarely need to LOAD a new linetype for just that reason, as the usual suspects are all called out in each of my many different custom templates. Quote Link to comment Share on other sites More sharing options...
gotchy Posted July 14, 2013 Author Share Posted July 14, 2013 Thank you all for your help. I used v 2007 and the word LTYPE at the command line and it works just fine. Thanks again, gotchy Quote Link to comment Share on other sites More sharing options...
