automaticad Posted July 13, 2013 Share Posted July 13, 2013 How to adjust the transparency of an image in the AutoCAD? Quote Link to comment Share on other sites More sharing options...
nestly Posted July 13, 2013 Share Posted July 13, 2013 "Fade" is available from the Ribbon via Contextual Tab States by merely selecting the Image "Fade" and "Transparency" are available via the Properties Palette. Type a numeric value (0-90) into "Transparency" field. Click the elipsis buttons in "Image Adjust" section to access the Brightness/Contrast/Fade settings Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 13, 2013 Share Posted July 13, 2013 I'm not sure transparency was available in ACAD2000 as shown in the OPs profile. You may be out of luck, if you are still using it. Quote Link to comment Share on other sites More sharing options...
