RobinF Posted July 15, 2013 Share Posted July 15, 2013 Hey! I got a work that I have to change around 1200 drawings from Microsoft Visio to AutoCad 2009. One annoying thing is that the Visio drawings got Arial as text style and my company want everything in their own textstyle. So at the moment I single click all text bar and change the style, there must be a faster way to fix this. I look through so threads and havn't found anything that solved this, so sorry if this is repost. Thanks for fast replies! - Robin F Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 You have to change the text style in 1200 drawings? Sounds like a job for a batch processing script. Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 You have to change the text style in 1200 drawings? Yes, acctually 1234 drawing but already managed about 100. It is alot more the text to change, some lines gets really wierd and where to lines conect i have to do a kind of symbol. But yes, a script would be great. If I only knew how to do them Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 If it is more than just changing a text style then some additional information will be required. Batch processing via a script works best when the same change(s) have to be made to each and every drawing. Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 Well the most consuming part is to change text style. The other things they vary so I can do them manually. Isn't there a command that change all text styles in a drawing, or that I can select several text boxes? Thanks for the fast response Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 The point is you want to do this another 1233 times isn't it? How many text styles are going to be changed in a single drawing? Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 Yeah, I have to do it some times.. In each drawing it is 10-40 text boxes that have to be changed and all will go from Arial to isocp. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 This is what you said previously: "...change all text styles in a drawing." That's why I asked if you were changing more than one text style. The script doesn't care if there are four instances of text that use the style or forty thousand; it's still only one style. Understand? Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 Yes I understand. And I only change one text style from Arial to isocp. When I said "all text styles" I ment text boxes, sorry for that. So yes there is only one text style to change. Arial -> Isocp Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 Read this brief tutorial about writing a script by Ellen Finkelstein and tell me if you understand it or not. http://www.ellenfinkelstein.com/acadblog/tutorial-automate-tasks-with-a-script-file/ Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 I've read it now but i don't understand how I should write it. Not how I should write that it will change several texts. The first line i guess should be something like "Select an annotation object or [undo]:" because that is what enters the command box when I want to change the style. Can you please give me a start so I can finish it? Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 You forgot already it seems. You are changing one STYLE and you are doing it globally (i.e. - the entire drawing). Since a script cannot directly access a dialog box one must use the command line version of the command itself. In the tutorial I pointed you to that was the -script command. Quote Link to comment Share on other sites More sharing options...
RobinF Posted July 15, 2013 Author Share Posted July 15, 2013 Yeah I will be changing one style and I understand that it will change the entire drawing. But I dont understand how I will write the script that i will change all text boxes. The command version i guess is DDEDIT... Sorry, I am new to this.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 Forget "all the text boxes" please. Concentrate on the one text style. Here is a sample script. _open C:\test.dwg -style standard isocp 0 1 0 n n qsave close Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 15, 2013 Share Posted July 15, 2013 Changing the text style will only work if the styles have not been overwritten in the MText box, which is often the case with converted files. There are a couple of LISPs around that will easily remove that formatting from all of the text entities. I use STPMtext. That is a simple one, others have some nice options. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 You can use Lee Mac's Script Writer to simplify your script and handle the task of batch processing. Find it here... http://lee-mac.com/scriptwriter.html Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 15, 2013 Share Posted July 15, 2013 (edited) Did you at least test the sample script file? The above script file assumes that you used the default text style named "Standard" that happens to have the Arial font assigned to it. All the script does is change the font to Isocp then it saves the drawing. Edited July 15, 2013 by ReMark Quote Link to comment Share on other sites More sharing options...
