Zox Posted July 17, 2013 Share Posted July 17, 2013 I found this tutorial for making un-plastered stone wall but in 3dstudio. Could something like this be made in autocad? Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 17, 2013 Share Posted July 17, 2013 (edited) Yes, it's just going to take more time and probably a different method. Edited July 17, 2013 by ReMark Quote Link to comment Share on other sites More sharing options...
Zox Posted July 17, 2013 Author Share Posted July 17, 2013 so is there maybe some tutorial at least similar you could recommend? Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 17, 2013 Share Posted July 17, 2013 Not that I am aware of. Quote Link to comment Share on other sites More sharing options...
f700es Posted July 17, 2013 Share Posted July 17, 2013 The material setup will be the tricky part. The modeling is not a problem with current AutoCAD versions. Using 2012/2013: Using the default 3D Modeling workspace in the Mesh tab. Select the Mesh Primitive Options (little arrow at the bottom of Mesh Primitives) Set up your divisions like they have, 7x4x1. Then click on the Mesh Box icon in a 3D view to draw out your mesh box. Change to a front view to adjust your vertices. Make sure you select Vertex in your filter list. Then just start moving the points around as needed. When you are finished here move back to a 3d view so you can "bevel" the faces. With this you need to have your filter set to face so you can select just the face. I had to select each face at a time and extrude with a bevel to get a similar look. This is as far as I got in a few minutes. Maybe someone else can jump in for the textures/materials. Sean Quote Link to comment Share on other sites More sharing options...
Zox Posted July 18, 2013 Author Share Posted July 18, 2013 ok super! thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 18, 2013 Share Posted July 18, 2013 Zox: When you are finished with your wall perhaps you can post an image? Quote Link to comment Share on other sites More sharing options...
f700es Posted July 18, 2013 Share Posted July 18, 2013 Looking back it might best to apply the different materials to the faces before adding the bevels, like they did in the Max tut. Quote Link to comment Share on other sites More sharing options...
