GISdude Posted July 19, 2013 Share Posted July 19, 2013 Hey guys, I have been tasked to do plan and profiles (w/o CIVIL3D), in MAP3D. I have a good set of LISP routines to create the sheets. HOWEVER, I was wondering about the VERTICAL scale. When I create a new map, I always define the coordinate system. BUT, I NEVER have to use a VERTICAL DATUM when I do my maps. I'm wondering are there advantages/pitfalls to not using a vertical datum when do the PNP sheets? In other words, I like to be fairly precise when creating lot lines/row's/pue's, but when doing the vertical scale is it that important? I might be just grasping here... Thanks for any help... Quote Link to comment Share on other sites More sharing options...
DBLS Posted May 5, 2014 Share Posted May 5, 2014 Just recently running into a bunch of these myself, I'd say to definitely use one. I was unfortunate enough to inherit a mixture of profiles with different vertical scales and had to combine them into a single profile, all of them Land Desktop Data into C3D data... and from the start, would have been much easier had they been created from the get-go with proper vertical scaling in mind. Especially considering the vertical scale chosen on a few of them resulted in entire D size sheets as a profile, which looks absolutely ludicrous Quote Link to comment Share on other sites More sharing options...
