One time select lines to convert polyline
121madhu
(PE
join
lines,arcs select)
same prosses of PE but there is taking long time if have any lisp file .
select lines,arcs to convert polyline.
lines,arcs old layer but new polyline take new layer
thank you cadtutors
(PE
join
lines,arcs select)
thank you cadtutors
This ?
(defun c:foo (/ ss)
 (if (setq ss (ssget "_:L" '((0 . "LINE,ARC"))))
 (command "_.pedit" "_multiple" ss "" "_y" "_join" "0.0000" ""))
(princ))
hello tharwat
My English is very poor actually i am interested to learn lisp programs but where can i found best definitions about defun , set ,setq, ssget, progn, i dont know everything
im also vist afralisp site.
your reply my previous thread thanks and ur code is working thank you very much being support
You're welcome and I just wanted to know if I got you right and brought the correct code for you .
hello tharwat
The Acad help document is one of the best books that you can use for learning and the online websites of course and Afralisp is one of the best of them .
Good luck
nice
but old lines,arc are available in old layer, new polyline generate new layer
If all entities are on the same layer , the new created polyine would be on the same layer otherwise one layer would be picked from one the selected objects .
i am facing new problem please give me another suggestion
lines and arc selected make a new polyline older lines and arcs are same but take a new polyline selected object its option very useful for me
