Results 1 to 8 of 8
    Senior Member Vagulus's Avatar
    Vagulus's Computer Details
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Samsung Synchmaster 940BW
    Inventor 2014
    Jul 2013
    Perth, Western Australia
    176
    Default My printout is only layer 0
    I have a simple drawing (very suitable since I am very much a newbie) with the object drawn on Layer 0 and the dimensions on another layer named (by way of novelty) Dimensions.
    When I sent this drawing to print I only get Layer 0 - no dimensions.
    In photoshop-type applications the process is called flattening, whereby all the layers are compressed into the base layer.
    Is there a similar process in AutoCAD?
    Do I have to use it to get all layers in the one print-out?
    How should I go about getting both object and dimensions to print?
    "Insanity is doing the same thing
    over and over again
    and expecting different results."
    Albert Einstein
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    So you have 3 layers in your drawing... right? (0, Defpoints, and Dimensions)
    Open the layer manager and see if Dimension layer has a Red circle and X in the column for "Plot" (the 9th column after the layer name)
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Is this what you mean by Layer Manager?
    That's what I have.
    over and over again
    Albert Einstein
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Actually, This is what I have
    over and over again
    Albert Einstein
  5. #5
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Ah, Ha! Click on the third icon in the plot row and the STOP sign goes away. Then the dimensions print.
    Thanks.
    over and over again
    Albert Einstein
  6. #6
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    See the red mark on the printer icon on the right side? That means the layer will not plot. Uncheck it.
  7. #7
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Now, let me answer your next question which is "How did that get checked... .I because I didn't check it"?
    When you create a new layer, the new layer inherits the properties of whichever layer is highlighted in the Layer Manager, so you probably had Defpoints (which is a non-plot layer) highlighted when you made the "Dimensions" Layer.
  8. #8
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Thanks again
    over and over again
    Albert Einstein
  1. viewbase printout resolution
    By stenews in forum AutoCAD General
    Last Post: 25th Apr 2012, 03:13 pm
  2. Printout does not match the plot preview
    By Rage221677 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Dec 2010, 02:58 am
  3. How to show file location on printout?
    By manyee in forum AutoCAD Drawing Management & Output
    Last Post: 4th Mar 2010, 11:35 pm
  4. multiple viewports in one printout??
    By loadbank in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2009, 12:31 am
  5. redrawing a printout to autocad
    By madaryl in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2007, 09:46 am
Tags for this Thread
