Results 1 to 2 of 2
    Full Member
    AutoCAD 2000
    May 2013
    38
    Default Involute of a Circle
    How to draw the involute of a circle?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    An involute is the curve generated by unwinding a string from the shape.
    If you had a later version of AutoCAD this would be easier using Parametric dimensions and constraints.
    It would take a lot of measuring and/or calculating in 2000.
    In a program like Autodesk Inventor you could enter an equation curve and the software will generate the curve for you.
  1. Involute Curve in AutoCAD?
    By spinecad in forum AutoCAD General
    Last Post: 28th May 2013, 08:09 am
  2. LISP routine for 2D internal involute gears.
    By Chiefsmack in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2013, 04:19 pm
  3. Accurate involute.
    By Lurking in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2012, 12:02 am
  4. Involute spline Specifications
    By prasanth14026 in forum AutoCAD General
    Last Post: 1st Mar 2011, 05:54 am
  5. circle center line(Like Plus symbol and after circle 4 sides 5mm extra length)
    By johnpieter in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Dec 2010, 02:23 pm
