Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 59
Thread: Standard scale
  1. #21
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by steven-g View Post
    The standard and custom scale headings in properties are only available when you highlight paperspace viewports, they won't show in model space viewports, or when a paperspace viewport is activated.
    I'm wondering if the OP overlooked this answer from another LT user. I don't see where he responded to it.
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  2. #22
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    abraCADabra, I click on vp scale box with an arrow and it maximizes the viewport. Does not reveal Standard scale/Custom for scale selection.
  3. #23
    Senior Member Fire_col's Avatar
    Fire_col's Computer Details
    Windows 7
    Construction
    Fire_col's Discipline Details
    Contracts/Design Engineer
    Construction
    AutoCAD 2013
    Feb 2010
    Nottingham/Derby UK
    238
    Walter. Just post your file for us to see, otherwise we're not going to be able to help you!
    If you don't say what you mean, you won't mean what you say.
    Yeah how d'you like them apples?
  4. #24
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by WalterCarlson View Post
    JD Mather, This is exactly what I am searching for.....
    But yet, you still ignore the information that I'm searching for to help you - the actual file.
    If you don't know how to attach the *.dwg file here - ask.
    While I am at it.
    Did you reboot the computer and this problem persists?
    Does this problem occur with any new file or just this one on particular?
  5. #25
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    ....box with an arrow and it maximizes the viewport. ....
    Maximize Viewport.jpg The tool on the left is not the same as the tool on the right.
    The tool on the left Maximizes/Minimizes your viewport.
    The tool on the right ONLY appears if you select a viewport boundary.
  6. #26
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Boundary not selected. Viewport Boundary selected.
  7. #27
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD Mather, Sorry, I am trying to the best of my knowledge to answer each and everyone's question. I don't know how to attach the file. I did reboot the computer and the problem persists. The problem is with all of my (present and past) files.
  8. #28
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD Mather, My screen shows he tool on the left but does not show the tool on the right.
  9. #29
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    http://www.cadtutor.net/forum/faq.ph...b3_attachments
    Are you sure you are in Paperspace Layout (bottom left corner indicates).
    Are you sure the viewport boundary is on a visible layer and not locked? I'm guessing the book might have had you Lock the viewport. Hmmm, well I just checked and the scale should appear even if the boundary is locked - as long as you have the boundary selected. But if you select that Maximize there is no way to select the viewport boundary - so click again for Minimize.
    Are you sure you have selected the viewport boundary?
    (also - if you double click inside the viewport, but I recommend that you don't do this until you have more experience to realize what this actually does)
  10. #30
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD Mather, I am in Paperspace; viewport boundary is not locked; I am certain I have selected the viewport boundary.
  1. Standard scale of a viewport
    By dannywi77iams in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Feb 2012, 01:13 pm
  2. Is There a Standard for Symbol Sizes that are Not to Scale?
    By David_Feynman in forum CAD Management
    Last Post: 3rd Jun 2011, 01:23 am
  3. Replies: 7
    Last Post: 22nd Sep 2010, 03:51 am
  4. Confused about "standard scale" and "custom scale" interaction.
    By tnb23 in forum AutoCAD Beginners' Area
    Last Post: 28th Jan 2009, 10:38 pm
  5. Standard drawing scale
    By heretic in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2006, 04:54 am
