Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    AutoCAD 2007
    May 2010
    36
    Default Dimensioning a 3D model as sketch in paperspace
    Hi All,
    Does anyone know if this is possible? I’m looking to model abasic part in 3D then throw some dimensions on it in paper space for quotationpurposes. The problem I have is even when I try aligned dimensions theextension lines from the dimension are not in the same line if vision as themodel (and this just looks awful). The parts are so basic they do not warrant a proper 3 view orthographicdrawing as a simple 3D sketch will suffice….Does anyone know how to achieve this inAutoCAD?
    Thanks in advance…………
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Create a layer in Model Space for your dims. It's much simpler than trying to dimension something that resides in Model Space when you are in Paper Space. I can see no merit in that approach.
    If you make your dims associative you have no scaling problems in Paper Space.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    Full Member
    AutoCAD 2007
    May 2010
    36
    Thanks this has all the dimension lines in the correct view planes. The only issue now is the text is very oblique so is a little unreadable.....do you think there is anything I could do to improve this?
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    I agree with Tyke, this is much easier in Model Space with coordinated UCSs. It is possible, however, by applying the _dimedit command with the Oblique option. See attached.
  5. #5
    Full Member
    AutoCAD 2007
    May 2010
    36
    Seant - That is exactly what I want to achieve.........I will have a play around with this
  6. #6
    Full Member
    AutoCAD 2007
    May 2010
    36
    Seant - Would you mind giving me a run down on how you dimensioned that part up? Thanks
    The dimension in MS with respective UCS is a quick way of doing it (thanks Tyke) and although this is what I'm after, as these parts are so basic...but on the other hand I do want my work to look professional and I think the paperspace method you mention gives that.
  7. #7
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    First off, I should also mention that PaperSpace dimensioning as shown in that previous attachment is only accurate for spans aligned with one of the orthogonal axis (X, Y, or Z).
    For instance, putting a Dim on the hypotenuse of the angular notch would not give an accurate value.
    I used the DimAligned command for initial placement. I then went back to realign everything with Dimedit - Oblique. For the most part I set the new angle based on how I thought the dim structure needed to be modified - either 30 or -30. It was not always intuitive, though, and I had to redo the command several on certain Dims to get a rotation I was somewhat happy with.
  8. #8
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    679
    AutoCAD 2013 has much better tools for this - if you can get hold of a copy...
  9. #9
    Full Member
    AutoCAD 2007
    May 2010
    36
    What are the commands for the 2013 version.......thanks
  10. #10
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by vards01 View Post
    Viewbase would give you the traditional orthographic views in a flash.
  1. how to switch from model to sketch
    By ntambomvu in forum Autodesk Inventor
    Last Post: 25th Jun 2013, 04:45 pm
  2. Circle dimensioning & inserting a sketch to an idw
    By rdharvey in forum Autodesk Inventor
    Last Post: 2nd Nov 2011, 09:13 am
  3. Dimensioning in Paperspace - What do you do?
    By bbankston in forum AutoCAD Drawing Management & Output
    Last Post: 9th Nov 2010, 12:04 am
  4. Dimensioning Multi lines in paperspace
    By Wavada in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Nov 2009, 12:51 pm
  5. dimensioning in paperspace
    By cuzzi in forum AutoCAD Beginners' Area
    Last Post: 21st Aug 2006, 05:24 pm
