Results 1 to 2 of 2
    Junior Member
    AutoCAD 2010
    Jul 2013
    10
    Default assigning easting & northing coordinates to origin
    hi
    is it possible to assign easting & northing coordinates(gps coordinates) to origin or any other point in drawing so that i can find the others with respect to that?
    if possible plz help..
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    920
    In 2010 version you need the Google Earth add-on from Autodesk Labs that is no longer availalbe for down load. With newer versions of AutoCAD (2014) there is a geolocation tool. Or if you use Autocad map3d or Civil3D its build in. Keep in mind if you are using sports grade GPS that the output is in Lat/Lon.
    Murph
    Need a boat or camper for the weekend?
  1. labelling Easting & Northing coordinates
    By kallerman in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2013, 05:29 pm
  2. Gps coordinates (northing & easting)
    By NSSC in forum AutoCAD General
    Last Post: 25th Oct 2012, 01:39 pm
  3. Help: Northing and Easting??
    By tzframpton in forum Civil 3D & LDD
    Last Post: 15th Feb 2011, 02:37 pm
  4. Attributes - Northing/Easting
    By SAM24462 in forum AutoCAD General
    Last Post: 7th Apr 2010, 02:47 pm
  5. Northing and Easting tags?
    By BigMikeLV in forum AutoCAD Drawing Management & Output
    Last Post: 18th Nov 2008, 04:45 pm
