Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Junior Member princessmonsta's Avatar
    Utilities
    AutoCAD 2012
    Jul 2013
    Perth
    11
    Default View Bound XREF's that are now blocks
    Hi, I'm not a Autocad Draftee. I'm a document controller that is trying to ID the situation with 2600 drawings. Some files are so large - 250,000kb, they won't open. They have bound xref's in them. We want to ask the contractor to unbind them and attach them as normal xref's. I need to view if a drawing has bound xref's. I just want to see them as BLOCKS which I now understand they are. How do I do view the blocks that were once xref's? Is there a way to do that?
    AutoCAD 2013
    Nov 2011
    6,056
    Welcome to CADTutor.
    An onerous task.
    You are absolutely correct, that they would work a lot better if they contained XREFS.
    I don't know a way to determine that, if you enter XREF at the commandline it will open the
    XREF dialog, but once an XREF has been bound into a drawing it will no longer show up on this list,
    because, you guessed it, it is no longer an XREF it has become a BLOCK REFERENCE.
    There is a command which will convert an existing BLOCK REFERENCE in a drawing into an XREF.
    Perhaps one of the lisp meisters on the forum could create a lisp to batch check through
    all the drawings, and make that conversion as they are checked.
    This sounds like a job for Lee Mac! http://www.lee-mac.com/index.html
    I am guessing that with 2600 drawings to be dealt with, the scope of the project would not
    prohibit a little paid programming to get you the tools you need, which you could then have in your quiver
    for the next time this happens, as obviously it will. Who knows, next time it could be a LOT of drawings!
    Lee is very talented, I would contact him and discuss the possibility of him writing a custom code for you.
    His contact information is linked on his home page.
    Utilities
    AutoCAD 2012
    Jul 2013
    Perth
    11
    Thanks so much for your reply. I guess I should have clarified. How do I see if an xref has been converted to a block? How do I tell? How do I see the blocks?
    AutoCAD 2013
    Nov 2011
    6,056
    As I said in my earlier post I don't know a way to determine if an XREF has been converted (bound into) the drawings,
    or merely inserted, as they would both then be identified as block references, once in that condition.
    Perhaps there is a way, and somebody else will be able to tell you how, hope so.
  5. #5
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Do you know if a specific naming convention was used for the Xrefs, that might enable you to check for specific block names in a drawing. Without code you could then look in the autodesk design center (command "adc") select the drawing, then select blocks and on the right you will see all blocks in the drawing with a thumbnail image. If an xref naming convention has been used and adhered to, you can then see if a drawing originally contained an xref.
    For example an xref called Xref_Titleblock if bound will have a block name called Xref_Titleblock.
    With adc you dont actually need to open the drawing itself.
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by feargt View Post
    Well done feargt, I have never used the design center, sounds like I should check it out.
    I work with Xrefs all the time, but they are never bound.
  7. #7
    Super Member PotGuy's Avatar
    PotGuy's Computer Details
    Windows 7 Premium
    Structural
    PotGuy's Discipline Details
    Temporary Works
    Structural
    (Trainee) CAD Techie/Draftsman
    Revit 2017
    Oct 2012
    London
    728
    Quote Originally Posted by princessmonsta View Post
    Lee also has snippets of code on this Forum, and to my knowledge not one has never worked! (I know, double negative!)
    Have a search on the Forum, as one of these routines might work.
    He's a fantastic LISP writer.
    This space changes a lot. Normally dependant on mood.
    Smilies are abundant in my posts.
    There's no crying in CAD but there sure is a lot of whining not to mention gnashing of teeth, pulling of hair and cursing - ReMark
    There is no crying in CAD. Only mouse slamming and keyboard smashing - RobDraw
  8. #8
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    You can check to see if the XREFs were bound by opening the XREF manager, type XREF + enter at the command line. If there is a list of files, then the XREFs were not bound. If the XREFs were indeed bound, they should be visible upon opening the files.
    Drafting is a breeze.
  9. #9
    Utilities
    AutoCAD 2012
    Jul 2013
    Perth
    11
    That actually doesn't actually work. Doing that returns just the original opened file with no reference to bound XREFs. To view bound XREFs, click on Tools, AutoLISP, Visual LISP, View, Browsing Database, Browse Blocks. That shows them with the $0$. But thanks anyway for responding!
    Bind
    Converts a specified DWG reference into a block, making it a permanent part of the drawing.
    The xref-dependent named objects, such as layer names, of the former xref are added to your drawing. In each xref-dependent named object, the vertical bar (|) is replaced with three new characters: a number
    (usually 0) between two dollar signs ($). The number is increased if the same name already exists in the current drawing.
  10. #10
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Regarding Bind - that is dependant on what bindtype was set to....
    BINDTYPE (System Variable)
    Controls how xref names are handled when binding xrefs or editing xrefs in place.
    Type: Integer Saved in: Not-saved Initial value: 0
    0
    Traditional binding behavior ("xref1|one" becomes "xref$0$one")
    1
    Insert-like behavior ("xref1|one" becomes "one")
    Therefore if "1" was used, then based on the layers in the drawing alone you won't know if an xref was bound or not.
  1. Where to insert xref section view
    By Keblapeb in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Apr 2013, 08:30 am
  2. What exactly is Upper Bound and Lower Bound?
    By rythem_of_the_nig in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Aug 2011, 02:49 pm
  3. Bound XREF Linetypes
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2009, 07:20 pm
  4. Xref does not appear in View Port
    By muck in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2008, 05:07 pm
Tags for this Thread
