crowscratch Posted July 30, 2013 Share Posted July 30, 2013 I am looking for a lisp routine that will increase the current value of attribute block by one. there a multiple tags in this block so will need to input which one to select. I am aiming to change i.e., (attribute value=) 1000350-1 into 1000350-2. Each drawing has a different number. Was wondering if a Lisp could read and select the attribute increase its value by one and either increase current value and/or replace to reflect new value. Any help would be awesome. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted July 30, 2013 Share Posted July 30, 2013 i use this lisp. Try it and tell me... Increment.dcl Increment.lsp Quote Link to comment Share on other sites More sharing options...
crowscratch Posted July 30, 2013 Author Share Posted July 30, 2013 Nice lisp but not what I am looking for. I didn't want to replace what was being inputted. Possibly looking for something a little more automated since I have about 500 drawings to update. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2013 Share Posted July 31, 2013 ok. Good luck .... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 31, 2013 Share Posted July 31, 2013 (edited) Welcome to CADTutor. Have you considered using this one by LeeMac? http://www.lee-mac.com/numinc.html It is just one of the many great lisps Lee makes available on his site for free, you should check them out. Thanks Lee! Edited July 31, 2013 by Dadgad Quote Link to comment Share on other sites More sharing options...
Guest Posted July 31, 2013 Share Posted July 31, 2013 Have you considered using this one by LeeMac? http://www.lee-mac.com/numinc.html It is just one of the many great lisps Lee makes available on his site for free, you should check them out. Thanks Lee! Yes this is a great lisp. Good job Lee !!!! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 31, 2013 Share Posted July 31, 2013 Cheers guys, I hope the program is useful to the OP Quote Link to comment Share on other sites More sharing options...
adryden Posted June 13, 2014 Share Posted June 13, 2014 I've used increment.lsp and it is perfect for what I need. Does anyone know why it would work on one machine and not another? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 14, 2014 Share Posted June 14, 2014 You probably need to direct question to Lee, also the specs on other machine Autocad versions being used may give Lee a hint. Quote Link to comment Share on other sites More sharing options...
adryden Posted June 14, 2014 Share Posted June 14, 2014 You probably need to direct question to Lee, also the specs on other machine Autocad versions being used may give Lee a hint. Thanks BIGAL! Quote Link to comment Share on other sites More sharing options...
Vinoth.s Posted October 11, 2019 Share Posted October 11, 2019 On 7/31/2013 at 1:21 PM, Dadgad said: Welcome to CADTutor. Have you considered using this one by LeeMac? http://www.lee-mac.com/numinc.html It is just one of the many great lisps Lee makes available on his site for free, you should check them out. Thanks Lee! it's working thanks lee Quote Link to comment Share on other sites More sharing options...
