Results 1 to 5 of 5
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    Default A drawing with a hatch problem
    I've received a drawing from a prospective client in both DWG and DXF format. Both show a hatch pattern or masking pattern of some sort that I can't deal with. A simple right click highlights every thing and crashes my program. I have a weak computer, obviously. Turning the "0" layer off does nothing for me while turning off the "face" layer removes everything when viewed in model space. I then see no design and no hatch. I do not use view ports or paper space at all at my level of ACAD use, just model space.
    The files were converted through the use of 3DSMAX by my client; how they were originally designed and executed I have no idea. Judging by the number of grips that show up, this design has a ton of very short entities and I need to lessen that number considerably for machine movement purposes. I'm attaching the file (I hope) in hopes that someone can explain what was done with this hatch and how to get rid of it in my 2011 LT program so I can work with it. Thank you for taking a look.
    Ken
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    I was able to erase it leaving spline objects.
    You can try turning grips off, at the command line enter GRIPS, enter, 0, enter.
    Also, HIGHLIGHT, enter, 0, enter.
    Now try erasing it on your own.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    Is there an easy explanation of how you did it? I've been fussing with it for 3/4 of an hour before I posted it with a revised name. I'll download yours to see how, too.
    Let me rephrase that; where was the hatch? On the "face layer"?
    It will take me a while to process figure it out but I will be back.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Yes, the hatch was on the face layer, I moved it to it's own layer (and froze the layer), but I got a million errors when selecting it.
  5. #5
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    I got the same "failure in face-face intersection" etc. but not the Boolean one.
    Edit to add: from the ribbon, I went draw-hatch, then pulled a window around the whole thing, then from the boundaries section I chose "remove" and that seemed to get rid of it. I tried it on the original and it worked as well. I've actually never seen the "hatch" creation tool bar before. Totally new to me today.
    Nestly, from your drawing, when I thaw the hatch, it works differently than the original but I can't see why. I'm not going to worry about it, as long as I can get rid of it then I can work on it without crashing.
    Thanks to both of you for the assistance.
    Ken
  1. Hatch problem
    By Tsirw in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 23rd Apr 2013, 08:30 am
  2. Ortho Problem/Hatch Problem
    By rydep12 in forum AutoCAD General
    Last Post: 5th Dec 2011, 12:28 pm
  3. hatch problem
    By happyunited in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2008, 08:47 pm
  4. Hatch problem
    By fiesta26 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Aug 2007, 03:30 pm
  5. Hatch problem
    By Jking in forum AutoCAD General
    Last Post: 1st Aug 2007, 06:00 pm
