KTS Posted July 31, 2013 Share Posted July 31, 2013 Hi there, Am having trouble drawing a ring beam round a building structure at an elevation of +2400 mm above floor level. Any help/ideas will be appreciated Thanks Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 31, 2013 Share Posted July 31, 2013 Draw the profile of the shape of your ring beam in 2D. Create a polyline describing the PATH around the perimeter of the structure. Use the SWEEP command with the PATH option to create a 3D model of it. Once created you can set the correct elevation. Quote Link to comment Share on other sites More sharing options...
