Results 1 to 7 of 7
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    Default PS - view '100%'
    Hi
    there must be a quick way (/)... or at least a way:
    like in Excel & Word & many other progs, when in PS i'd like my view to be at 100%....so if i plotted, my (eg) PS titleblock would be the same size on paper as on the monitor.
    P.S. i fully admit i looked in AutoCAD help for about 30secs, then posted here
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by mikekmx View Post
    ...like in Excel & Word... ... same size on paper as on the monitor.
    I am curious - I want to know how to have Word print the same size on paper as on the monitor? (I have never ever had the need for this - but as I stated - curious.)
    I always print paperspace at 100%, but that isn't necessarily the same size it displays on the monitor?
    Can you attach a sample file here to illustrate your problem?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,506
    I don't see the point of printing something at the same size as it is on one's monitor. Please cite three examples.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I would say I don't see a need for this either, however to sync the sizes, simply divide the length of a sheet of paper by the length of the "paper" on the monitor (use a ruler) then ZOOM by the dividend while in PaperSpace.
    ...or buy an Asus monitor with QuickFit grid
  5. #5
    Electrical 2008
    Dec 2012
    UK
    445
    sorry, i didn't expalin very well...
    in PS, what i'd like to do is 'click' and zoom my view to 100% (or 1:1) so it's the same size as it will be on paper.
    the reason: at pesent i plot to PDF then view 100%, to check things are legible, check the vp scale is suitable etc. Being able to do this in AutoCAD would save some time.
    i try to set things up so my drawings are best plotted at A1 but are still legible if plotted at A3 size, but what tends to happen is they are too big on A1. i want to be able to check as i go along and with less effort.
    just bought a new HP 23" monitor, so the Asus is not an option
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    As far as I know, AutoCAD does not have a way to do that without the calculation that nestly mentioned. For your needs, I would think a close approximation would be good enough. Even with "Lineweights" turned on, what you see on the screen is not going to be exactly as it is going to appear on paper. PDFs viewed at 100% do not even do that. Most of the time they are close but I've seen some major differences between what a PDF shows on the monitor, especially when zoomed in, and what the printed PDF looks like.
    Drafting is a breeze.
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    ...to check things are legible....
    .... but are still legible if ....
    Text size (printed) should be the same on any size plot.
    For the geometry it should be obvious of sheet size/view scale that is needed.
  1. Model Space View to match Viewport View
    By Bobzy20 in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2013, 11:24 am
  2. Can visual styles work like model view, but in plan view?
    By Cad Monkey 2 in forum Architecture & ADT
    Last Post: 16th Jun 2011, 02:03 am
  3. View Isometric 3D and Its 2D Views( Top, Elevation and front View) !!
    By basiony in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 04:22 pm
  4. Replies: 9
    Last Post: 15th Jul 2010, 03:15 am
  5. Replies: 6
    Last Post: 13th Aug 2009, 03:59 am
