Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2014
    Aug 2013
    2
    Question Creating Bending Linetype
    Hi All,
    Generally for drawing cable, I use a p-line (generally curve or spline fit) and change my global width to the diameter of that cable. This is usually exactly what I need to show. HOWEVER, when a complicated drawing arises with several different types of cable in one particular area, I have to differentiate the cables by altering their appearance for ease of tracing that wire in a black and white printout.
    Before, I would offset the polyline to either side, close in the ends and fill with a hatch. This works ok, but is time consuming and the hatch doesn't rotate relative to the line.
    I tried to be clever with the express tools linetype creator, but autocad won out. See Pic for my attempt.
    It looks ok zoomed out (except for the dots in the center of the line, which need to go). However, when zoomed in, the curve is actually an assembly of straight segments that overlap on the inside and don't meet up on the outside of the curve.
    Can someone point me in the right direction for instructions, tips, pointers for creating "bending" linetypes? I've already accepted that I'm probably going to have to somewhat learn lisp... hit me with it.
    Thanks!
    Kyle
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Wouldn't the use of splines be more appropriate?
    Full Member
    JGA's Computer Details
    Win7
    AutoCAD 2014
    Jul 2007
    Scotland
    77
    Not sure how you would go about the problem above.
    How about putting your fat polyline on a layer that has a transparent value, so that others underneath are still visible? You could still have thin polylines either side with no transparent value.
    Forum Newbie
    AutoCAD 2014
    Aug 2013
    2
    Our customers receive hard copies and cad files of all drawings, which must adhere to their layer standards. So adding, changing a layer is a no-no. The spline method is the best I have right now. (spline the center line, offset half of diameter on either side, delete center, close off the ends, trim all in the background, hatch).
    I was really just looking for an easier method. So if this will not work for what i'm doing right now, can I still learn how to make a linetype that bends? I saw this linetype when searching for and answer and knowing how to make a linetype similar to this would be perfect for cables!
  5. #5
    Super Member prodromosm's Avatar
    AutoCAD 2014
    Jul 2010
    610
    I find this here http://www.cadlispandtips.com/2013/0...kerb-line.html .Maybe help you..
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    Quote Originally Posted by KyleA724 View Post
    Perhaps modify your way slightly by making a diagonal block, and then place it along the centre polyline using Measure. This is almost hatching but does rotate with the curves.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Kyle:
    I can point you to a custom lisp routine that will align a hatch pattern to fit a curved path if you are interested.
  8. #8
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,466
    I created that linetype for a client, and I responded to your blog post comment, here.
    R.K. McSwain
    CAD Panacea | twitter
  1. creating new linetype
    By soozyq in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 13th Sep 2011, 08:03 pm
  2. Creating linetype
    By diablo98 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Nov 2009, 11:06 pm
  3. Help with creating a linetype
    By Chudwick in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Nov 2008, 02:23 am
  4. creating new linetype
    By chelsea1307 in forum AutoCAD General
    Last Post: 25th Sep 2008, 11:11 am
  5. creating a linetype
    By jjjgirling in forum AutoCAD General
    Last Post: 7th Mar 2006, 12:26 pm
Tags for this Thread
