OooWeh Posted August 2, 2013 Share Posted August 2, 2013 Hello Everyone.I wonder if anyone can help. I am using Autocad 2012 and have found an online tutorial site very informative. The assignment in beginners lesson 1-2, drawing a simple line square, has me baffled As they mentioned in lesson1-1 that understanding coordinates is very important. Firstly, in 1-2, they ask the reader to select the line tool and then enter the first coordinate of 1,2 as the starting point of the drawing. Then the following entries 3,2 3,4 1,4 and 1,2 are entered and sure enough a perfect square is created. My first problem is: As many times I enter a starting point of 1,2 the line always starts in the same place. However, if I start again and enter any other figure the line starts in seemingly unrelated positions. The second problem is: the coordinates given in this exercise are not equal and should not create a square in my uneducated opinion. Try as I might I cant find the logical relation between the grid and the coordinates. For example: The starting entry - 1,2 starts 2 grid lines from the +Y axis and 4 lines from the +x axis. Please could someone help me understand this problem so I can move on. I have scanned all the tutorials and videos I could find including AutoCad for dummies and cant find the answer. Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted August 2, 2013 Share Posted August 2, 2013 Look at the attached and see if it explains things for you. Quote Link to comment Share on other sites More sharing options...
eldon Posted August 3, 2013 Share Posted August 3, 2013 The second problem is: the coordinates given in this exercise are not equal and should not create a square in my uneducated opinion. Try as I might I cant find the logical relation between the grid and the coordinates. if you examine the differences in the x and y coordinates for successive points, you will see the logic that will create a square. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 3, 2013 Share Posted August 3, 2013 (edited) Watch out for Absolute coordinates # and Relative coordinates. AutoCAD used to default to Absolute and now defaults to Relative @. Edited August 3, 2013 by JD Mather Quote Link to comment Share on other sites More sharing options...
OooWeh Posted August 3, 2013 Author Share Posted August 3, 2013 Hi Rkent. Thanks so much for your effort. The penny has dropped. What I realized was that the grid actually appears in 1 half increments. I am no longer confused. Thanks Marc Quote Link to comment Share on other sites More sharing options...
OooWeh Posted August 3, 2013 Author Share Posted August 3, 2013 Thanks Eldon. Got it Quote Link to comment Share on other sites More sharing options...
OooWeh Posted August 3, 2013 Author Share Posted August 3, 2013 Thanks JD Your advise really helped. I can now safely progress to section 1.2. Quote Link to comment Share on other sites More sharing options...
OooWeh Posted August 3, 2013 Author Share Posted August 3, 2013 This forum is certainly one of the best I have had the pleasure of visiting. Quote Link to comment Share on other sites More sharing options...
