Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2012
    Aug 2013
    2
    Default paper space and line-weight confusion
    Hello!
    I'm working on my first autocad drawing and am struggling to work out what it will actually look like when printed! when i go onto paper space the look of the drawing (a building plan) completely changes when i move the cursor across it, from clumsy thick awkward lines to neat drawing with correct hatching etc...I hope my drawing is the latter but i suspect it isn't! How do I know for sure?
    this is probably a really obvious question but I would really appreciate some advice
    Thanking you in advance
    em
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    pdf it, then print the pdf, then you can be fairly sure that WYSIWYG
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    First, the different looks as you move your cursor are more than likely just the selection preview.
    There are a couple of ways to preview your lineweights within AutoCAD before printing. You can turn lineweights on. It's a button at the bottom of the AutoCAD window. Or you can do a print preview from the plot dialog window.
    Drafting is a breeze.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I am not sure why the extra step of saving to PDF for printing?
    Turning on lineweights is not WYSIWYG in AutoCAD.
    I set everything up in my template - so I know exactly how it is going to plot.
    Set it and forget it. Plots will always be consistent. Plots will always be perfect.
  5. #5
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I forgot to mention what JD has hit upon. Any type of plot preview on your screen, including PDFs, will not necessarily be exactly what you will get on paper. The print to paper is usually better than the previews.
  6. #6
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    When plotting from paper space you may (or may not) want to click the 'Scale Lineweights' option.
  7. #7
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    679
    I like having 'Display plot styles' turned on - just as JD suggests. It's kind of like having a permanent plot preview.
    Here's a post on Ellen Finkelstien's blog showing how it's done:
    http://www.ellenfinkelstein.com/acad...e-plot-styles/
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Pablo Ferral View Post
    Just to be clear - I was simply showing an option. I NEVER have that turned on - because I prefer to work in color (even though I plot monochrome) and I already KNOW what my plot is going to look like before I even started the drawing because my styles and standards are all set up in my template.
    In any case - this appears to be the typical student post - 1 post, no follow-up and gone.
    The assignment was due days ago.
  9. #9
    Forum Newbie
    AutoCAD 2012
    Aug 2013
    2
    Nope, still here!
    Thanks for all the advice! I found that print-preview works okay, and my drawings looked as I wanted.
    Display plot styles is also useful.
    thank you
  1. Dashed Line is Solid in Paper Space
    By bachrock in forum AutoCAD General
    Last Post: 11th Jul 2012, 05:32 pm
  2. Paper Space in command line?
    By Maxelkat in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2011, 12:11 pm
  3. One more with model space / paper space linetype confusion
    By the-trooper in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2010, 02:37 pm
  4. Text on Paper Space but with no line through it.
    By venuj99 in forum AutoCAD General
    Last Post: 27th Apr 2009, 03:04 pm
  5. Line Weight not showing up when printing in Model Space.
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Mar 2006, 05:28 pm
Tags for this Thread
