Rebar in Foundations
addesigns
Is there any add-in software or any way to tell Revit that you want certain Rebar in the foundation so that if you do a section cut it would show the locations?
Im not very familiar with Revit Structure but a co-worker thought it was possible. just wanted to ask everybody out there
No add-in needed. Select any concrete-based structural component and the Rebar Tool becomes available in the Ribbon. In the last two years, the rebar tools have significantly increased in functionality and efficiency. We model about 90% of our concrete structural elements now, because it makes it so easy to never mess with section cuts, and run reports and other info.
