Results 1 to 6 of 6
    Full Member Lentezza's Avatar
    Lentezza's Computer Details
    Mac OS X 10.6.8
    Macbook Pro 6,1
    Intel Core i7; 2,66 MHz
    8 GB
    NVIDIA GeForce GT 330M; 512MB
    Manufacture
    Lentezza's Discipline Details
    Furniture design and production
    Manufacture
    Mainly solid wood furniture
    AutoCAD not applicable
    Oct 2011
    Swizerland
    77
    Default Line perpendicular OFF another line
    Hello forum,
    is there a simple way for drawing lines or plines perpendicular off a given line which is not horizontal or perpendicular itself?
    Is there a way for drawing that yellow line in the drawing with a given lenght directly off the ending of the white line? Without using SNAPANG or thelike?
    Cheers
    Len
    I use AutoCAD for Mac 2013. I was never trained in using cad-programs, so I have little or no idea (about naming things with correct terms)...
    Please leave me alone with Mac vs PC stuff. It´s boring. (I had been working with AutoCad on a PC, so I know that there are differences...)
    Thanks for help anyway, whatever version or system you use!!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    You could use Polar Tracking.
    You could use the SNAPANG command.
    You could reorient your UCS.
    You could probably even find two other ways to accomplish the same task.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Does your version of AutoCAD have Constraints??
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,147
    Another vote for Polar Tracking.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Rotating the UCS is my personal favorite way to do that, some common methods are below.
    Draw a line perpendicular to the endpoint of a line.
    1. OTRACKING on,OSNAP endp and perp set, POLAR on, start line command,
    acquire end point, move 90 degrees in direction you want, type the
    value or pick, pick the point you first acquired. If there other lines
    at the endpoint of the target line you may not get the proper results.
    2. Rotate the UCS with the OBject option, and draw away. I have this
    automated with UO as my quick keys (UCS, OBject), and to go back I use
    UW (UCS, World).
    3. With POLAR set to Relative to last point, start the line command,
    use an osnap, pick the line, move 90 degrees in the direction you want to draw and enter
    the value or pick.
    4. Rotate the crosshairs with snap, rotate, pick two points on the
    line.
    5. MOCORO command to copy and rotate.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    Mac OS X 10.6.8
    Macbook Pro 6,1
    8 GB
    Manufacture
    Manufacture
    Oct 2011
    Swizerland
    77
    Thanx everybody for the replies!!!
    Funny enough, when trying to use your solutions I had to find out the thing I was looking for was already there and I appaerently had been ignoring it all the time!
    The only thing necessary to do was to shut off ortho, obviously...
    Looks like the OTRACKING is always "active" in my AutoCAD-Version, even when it´s set to "off".
    So the way to achive what I was looking for is doing is the way rkent is describing under "1." But with only OSNAP set to "on", no POLAR , no OTRACKING. When moving in the 90° direction I have a white x appearing (which I could not capivate with the screen shot here underneath) and "perpendicular" written.
    This is f****** practical!!!
    Thanx again everybody!
  1. Bisect Line and draw perpendicular line at midpoint
    By Baber62 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Nov 2015, 04:13 pm
  2. Perpendicular Line from A Line
    By vitrag60 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Nov 2012, 06:58 pm
  3. perpendicular from a line
    By Nina in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Oct 2012, 05:10 pm
  4. How do I draw a line that STARTS at a perpendicular angle to another line
    By nrschmid in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Jun 2012, 01:43 pm
  5. Need to find line that intersects with my perpendicular line
    By Proctor in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Feb 2010, 06:18 pm
