mitch_au83 Posted August 14, 2013 Share Posted August 14, 2013 hi all, we have just upgraded our autocad from 2010lt to 2014lt at work. would any one know how to make curved lines appear the same as they were in the 2010?? when you select a line with a radius in it, it used to have little arrows showing the line is curved and what direction. is this possible to change thanks in advance Quote Link to comment Share on other sites More sharing options...
nestly Posted August 14, 2013 Share Posted August 14, 2013 What you've described does not sound familiar to me. Any chance you can post a screenshot or manually add the "little arrows" with a graphics program to illustrate? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 14, 2013 Share Posted August 14, 2013 hi all, we have just upgraded our autocad from 2010lt to 2014lt at work. would any one know how to make curved lines appear the same as they were in the 2010?? when you select a line with a radius in it, it used to have little arrows showing the line is curved and what direction. is this possible to change thanks in advance Yes, the "little arrows" you are referring to were replaced by multi-function grips as shown below. Just hold your cursor on the endpoint grip, and then choose Lengthen from the contextual menu that appears. If that is not acceptable for you, then you can set GRIPMULTIFUNCTIONAL to 0, and get your "little arrows" back. Of course you'll lose other functionality of multifunction grips too. Quote Link to comment Share on other sites More sharing options...
mitch_au83 Posted August 14, 2013 Author Share Posted August 14, 2013 thats what i was after, thanks rkmcswain! the multi function is useful for text positions but not really of use to me for the lengthen/stretch cheers. Quote Link to comment Share on other sites More sharing options...
mitch_au83 Posted August 14, 2013 Author Share Posted August 14, 2013 is there a way to get the dim text position back on the right click menu?? with the GRIPMULTIFUNCTIONAL on 0 i lose the ability to move individual text?? thanks again... Quote Link to comment Share on other sites More sharing options...
nestly Posted August 15, 2013 Share Posted August 15, 2013 I'm going to precede the solution with my advice to turn Multifunctional Grips back on, as you'll spend more time trying to make AutoCAD2014 work like 2010 than the time it will take to learn to use the "new" grips more efficiently than the "old" grips. Your choice.... Find the command(s) in the CUI and drag them onto the Dimension Objects Menu Shortcut Menu. (the command to Reset Text position "Home Text" is shown below) Quote Link to comment Share on other sites More sharing options...
