gotchy Posted August 15, 2013 Share Posted August 15, 2013 Be there a way to increase the length of the lines in the center mark so that they do go out to at least the diameter of the circle, so that these lines can be used to trim parts of the circle? Gotchy Quote Link to comment Share on other sites More sharing options...
CADgirl Posted August 15, 2013 Share Posted August 15, 2013 Modify your dimension style. Under the Symbols and Arrows tab change the size of the center mark. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 15, 2013 Share Posted August 15, 2013 Check your dimension style settings. Quote Link to comment Share on other sites More sharing options...
gotchy Posted August 16, 2013 Author Share Posted August 16, 2013 Modify your dimension style. Under the Symbols and Arrows tab change the size of the center mark. Thank you ! Quote Link to comment Share on other sites More sharing options...
gotchy Posted August 16, 2013 Author Share Posted August 16, 2013 Thank you ! Quote Link to comment Share on other sites More sharing options...
