lknchoppers Posted August 16, 2013 Share Posted August 16, 2013 Hello, I am using AutoCAD LT 2012. I am having a problem getting a drawing to be the proper scale and units. I pulled a drawing in and it has been drawn 1' = 1 unit. I really would like to get it so I can make 1 unit = 1". I need to preserve the current dimensions in the drawing. What would be the best approach to be able to do this. Thank You. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 16, 2013 Share Posted August 16, 2013 Are you working with a paper space layout and at least one viewport? Quote Link to comment Share on other sites More sharing options...
rkent Posted August 16, 2013 Share Posted August 16, 2013 Without the drawing this is a guess. Scale everything in MS by 12. Edit the dimstyle and change from Decimal to Architectural. Post the drawing or a small sample for a better answer. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 16, 2013 Share Posted August 16, 2013 Welcome to CADTutor. I don't know if LT has the -DWGUNITS command (with the hyphen), or not. If you enter -DWGUNITS at the commandline, and the command is recognized, then take your time, read and follow the commandline prompts, and you will be walked through the whole process in about 4 to 6 steps. Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 16, 2013 Share Posted August 16, 2013 Welcome to CADTutor. I don't know if LT has the -DWGUNITS command (with the hyphen), or not. If you enter -DWGUNITS at the commandline, and the command is recognized, then take your time, read and follow the commandline prompts, and you will be walked through the whole process in about 4 to 6 steps. Has it. Works fine. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 17, 2013 Share Posted August 17, 2013 Has it. Works fine. Somebody must have forgotten to take it out! thanks Dana. Quote Link to comment Share on other sites More sharing options...
