Lentezza Posted August 21, 2013 Share Posted August 21, 2013 Hello, I have this drawing causing CAD to crash over and over again (doesn´t crash with other drawings!) Unfortunatly I am not able to understand what the crash report is telling me, or whether it could be of use for maybe removing the cause of them crashes. Anybody can help??? Here is the report (had to split it in 3 for uploading): Crash report1.doc Crash report2.doc Crash report3.doc Cheeers Len Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 Have you purged and audited the drawing? BTW...that would be the version of the purge command with the dash in front of it like this: -purge. Purge Regapps, then go back and purge All. Then do an audit. Have you tried to WBlock out the drawing? What other steps have you taken so far? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 Thanx ReMark! Tried all the things you proposed, unfortunatly didn´t change the situation... Before that I did´t try anything, apart from copying the whole drawing for pasting it into a new document. But the copying itself causes another crash... I don´t know any other methods. So: further advice very welcome. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 Doing a copy/paste is not the same as doing a WBlock. Are there any xrefs? What's the file size of this drawing? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 It´s 406kb xrefs? No idea, don´t know what they are... I´ll attach the drawing itself: I & L - Var 2.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 No problems here as the drawing opened fine on my system. I did run -purge (twice), overkill (once) and audit (once) before I started playing around with it. Used 3DOrbit with no problems. What were you attempting to do when the problem first occurred? Maybe I can force the problem by repeating what you did. Here is your drawing back minus a few bits. File size has been decreased a wee bit too. I & L - Var 4.dwg Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 I´ve been trying a few things now and it looks like I found something. But it´s a bit weird... The crashing occured when I was putting DIMLIN. Also with MEA. And as I said before when trying to copy the whole drawing (but copy and paste from one drawing to another has always been tricky on my system.) Now I found that the crash happens only when working in a certain area of the drawing and also only when working in front view. (when I put the drawing in front view I have readable red measurement annotation on the lower left corner of the drawing.) When working in other parts of the drawing or when changing view to SE - no crashes. Then I changed one of the objects in that zone (strechting a line or a corner) and after that I can do whatever I want, no more crashing. After that I even tried undo the change and the thing continued working. Closed the drawing without saving changes. Reopen. DIMLIN in the critical area of the drawing. Crash. ???????? However, if it keeps on working with the workaround I am happy enough.... Just a bit confused though.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 You do realize that your dimensions are sitting in front of your 3D model don't you? I think it crashes because of the method you are using to dimension your drawing. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 Yes, I did realize that. I think the crashing happend also before I put that annotations in. Anyways it would be good to know about a better method for dimensioning.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 Apparently when you dimension your UCS is not on the face of your object. Did you open and test my version of your drawing? Why aren't you using Flatshot or the Base View command to create 2D views of your 3D object and dimensioning them instead? Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 Sorry, didn´t notice you´d been adding a drawing before... Opened it now, same problems.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 The drawing does not crash when I open it so where does that leave us? The problem could be with your software or with your hardware. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 Sounds obvious.... Thanx for your help again anyways, in the end it helped me find a workaround. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2013 Share Posted August 21, 2013 If that is enough to satisfy you then so be it but as you get further into your drawing I suspect things will only get worse. Quote Link to comment Share on other sites More sharing options...
Lentezza Posted August 21, 2013 Author Share Posted August 21, 2013 The solution is not really satisfying on a learning level but it seems to be ok on a working level.... Always look on the bright side of Thanx also about the hints about dimension and ucs! Quote Link to comment Share on other sites More sharing options...
