setting a simple point
kltanker
I've tried to set a simple point in model space. I typed PO - enter - typed a pair of coords into the 2 boxes, and then enter. No point was created. What am I doing wrong?
You are not doing anything wrong. The point is there, you just cannot see it. AutoCAD, in their wisdom, set the default Point shape to be a dot. So you just have to change the Point type shape as in the previous post.
John 7911: your advice worked. After trial & error my procedure: type ddptype - enter - set pt size - check set size relative to screen - enter - type po - enter - click a desired point loc. The result will be the point style & size specified.
Thank you for the help.
