Results 1 to 4 of 4
    Senior Member
    AutoCAD 2010
    Apr 2011
    145
    Default Making points selectable
    Hi Folks,
    I have got points from a GIS software into AutoCAD, the problem is that I am unable to draw a polyline between the points to get a distance between the points. Does someone have a lisp routine which can convert the points to make them selectable. I have attached the drawing I am working on for those of you who want to have a go at this one.
    Thanks in advance.
    Super Member lamensterms's Avatar
    lamensterms's Computer Details
    Windows 7 - 64bit
    Manufacture
    lamensterms's Discipline Details
    Steel Detailer
    Manufacture
    3D Modelling - Mechanical & Structural 2D Detailing - Shop Drawings
    AutoCAD 2014
    May 2011
    Berwick, VIC, Australia
    569
    Gday mate,
    I'm sorry I don't have the ability to access your DWG (no CAD on the PC I'm currently using).
    But is it not possible to snap the the POINTs using the NODE snap?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,104
    These Points are in the default shape of a dot. Change the point shape as in this thread, and you can snap to them using the Node snap.
    No lisp is needed at this stage
    Senior Member
    AutoCAD 2010
    Apr 2011
    145
    Thanks Eldon ... that did the trick, appreciated.
  1. Please help with making contours from points
    By skills12345 in forum Civil 3D & LDD
    Last Post: 8th Aug 2013, 10:52 am
  2. non selectable objects on layouts
    By anp2012 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Dec 2012, 02:35 pm
  3. add subtract numbers selectable
    By clint0577 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Nov 2012, 09:17 pm
  4. Selectable/Unselectable Group
    By hericson in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Nov 2008, 08:38 pm
  5. non-selectable
    By DSCHNELL289 in forum AutoCAD General
    Last Post: 31st Jul 2006, 09:49 pm
Tags for this Thread
