Sirrojo Posted August 22, 2013 Share Posted August 22, 2013 I think this is possible, I just need the right formula setup. I need to generate a property set for the distance from the bottom of the floor deck above which I would like to set as a static elevation in the property set (520'-6") and use the formula to take the center of pipe calc and give me the answer so that I can use the label tag to tag all my pipe connections. I cannot figure out how to set the elevation number in my formula. Quote Link to comment Share on other sites More sharing options...
hertz hound Posted September 14, 2013 Share Posted September 14, 2013 Have you figured it out yet, or do you still need a hand? See if you can use the file I sent a link to in the post, "property sets, AEC spaces and tags." Quote Link to comment Share on other sites More sharing options...
